Shift Knob
Ok I made a shift **** in my shop class and because it looked so nice I wanted to put it in my car and was wondering whats involved with it. I have and 84 944. Thanks Gage
Hey Man
LOL I started to type a reasonable answer and then realized too many facts were missing. I will add though, if he uses the OE shift lever and tries to do a threaded Momo type mount, the vibration damage to his hand will render him unable to self pleasure himself for at least a month.
You can cut the original shift lever and weld on a rod with a threaded end to screw the shift **** on to. Then you have to modify the shift boot to fit the new shift lever.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
great call.... i was going to mention about the horrible vibration !!
hence, one more reason why i didn't hesitate on using duct tape in my 968 to 997 gear **** upgrade. i thought the duct tape (now an official part of my car) would solve any possible vibration issues that might come up running the harder ****, as opposed to using a harder epoxy.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
https://rennlist.com/forums/968-foru...uld-to-it.html
There's slight vibration but I don't mind it. Its nothing major... It depends on how creature comfortable and quiet you want the inside of the car to be overall.
I believe we would need measurements of the new ****, is it screw on or is there a retension allen screw, if screw on type thread count and thread depth in the **** would help, will you reuse the standard attached boot somehow or it that being replaced also?
And yes a pic is worth a thousand words.
Drill and tap a hole for 3/8 thread then just weld on a section of 3/8 rod to your shift lever and run a 3/8 die on the end. This is essentially what I did and it works well.
![](http://scotandlinnie.com/shift.jpg)
sorry its a little blurry, blackberry camera for the fail!
thats what i had done to mine. hope it helps, mine works great after added a lock nut to help keep it tight.
