Shift Knob
12-06-2010, 11:24 AM
Quote:
Originally Posted by
Gages 944
Could you get some pictures of what you did I am a little confused. Kinda getting what you saying.
This is the best picture I have... it's probably no help to you though.
12-06-2010, 11:40 AM
learning to read, for the win!
12-06-2010, 12:18 PM
AddictRennlist Member
928 Motorsports sells an adapter for $7.50 or you can fab your own.
12-06-2010, 06:12 PM
Ritzblitz that is what Im tying to do except my shift **** isnt going to be a ball. So all I have to do is thread the **** get a rod to put on it then weld the rod to the linkage? if so that is pretty simple.
12-06-2010, 06:31 PM
yeah tap and die and a welder. I cut the shift lever square and notched the rod to increase the surface area for the weld. You definitely don't want it breaking off while you're driving.
12-06-2010, 08:34 PM
Just weld a bolt to it, skip the die
12-06-2010, 10:44 PM
No I'll make the shift **** nice and I have it center drilled already. If I have the materials which I do I will make it nice.
12-06-2010, 11:00 PM
Gages 944
Good idea. A bolt would not turn out right unless you covered the entire lever with the boot.
12-07-2010, 12:55 AM
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
the solution is so simple. low production ***** don't need any of this fancy stuff. amazing.
12-07-2010, 01:01 AM
odurandina
blah blah duct tape blah blah blah
12-10-2010, 10:00 PM
This is my shift **** that will go in there.
12-14-2010, 05:11 AM
make that **** in a mill?
12-14-2010, 08:45 AM
I made it at school in shop class on some free time I had. I used a lathe.
12-14-2010, 10:04 AM
ritzblitz
I have a new sig quote... thanks ritz...
12-14-2010, 11:27 AM
JohnKoaWood
haha glad I could be of service.
