Sloppy Shifter fix (another way!)
I had the infamous football-shaped shifter peg and i tackled that this weekend. I checked around on here and i've seen the bolt fix, the copper tubing fix, and the plastic 924 bushing fix.
I liked the 924 bushing fix the best (some people said the bolt wore out their shift rod), but i don't have a Porsche dealership anywhere around, so i ended up doing it a slightly different way and i thought i'd share.
Found this guy at Autozone (note part number) for $10. It's a door hinge pin and bushing set for Fords. There were several choices, but this one looked like the best setup for its intended purpose.
![](http://i9.photobucket.com/albums/a60/cacollo/Porsche2/P1040755.jpg)
Cut the old football off, drill a hole (i forget which size, just use a mic on the smooth part), blah blah blah:
![](http://i9.photobucket.com/albums/a60/cacollo/Porsche2/P1040749.jpg)
Unbolt the shift rod back at the transmission. Use a pair of vice grips to hold it steady while you drill the hole out to 31/64" on both sides. You don't have to drill all the way through, just about .320" in so that the bushing will seat all the way.
![](http://i9.photobucket.com/albums/a60/cacollo/Porsche2/P1040751.jpg)
Ta-da!
![](http://i9.photobucket.com/albums/a60/cacollo/Porsche2/P1040753.jpg)
Press the pin into the hole you drilled in the shifter, then weld up the back side. Measure the pin length needed, cut a groove for a circlip, and cut the excess off. Install and you're done:
![](http://i9.photobucket.com/albums/a60/cacollo/Porsche2/P1040754.jpg)
It has a smooth feel and no slop! Extra heavy duty, too (if it can hold a door up, i think it can handle a shifter....).
Ta-da!
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Yeah, it really firmed things up, and it didn't take very long! Perfect project for the long weekend ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The only thing i couldn't figure out was which direction the plastic at the bottom of the shifter was supposed to face. I notice that there are two grooves cut into the face of the plastic--do those face front/back? I made sure those were facing front/back this time and it made my shifter very stiff. Not sure if that means it's incorrectly installed, or that it was installed incorrectly the last time i had it off....
I used the bolt trick but this looks great! Good work. I think I'll get a long bolt with almost no threads and cut the grove for the c clip and put the bushing in the shift rod. Like seems easier to me haha. Great work!!
