correct use of tools(funny)
The Correct Use of Tools
Most people who work on cars know that all tools have 2 uses; the one it was designed for, and the one it is used for. The following list demonstrates some of the latter uses of tools.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats covers and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Ouc...."
HYDRAULIC FLOOR JACK: Used for lowering a car to the ground after you have installed your new headers, trapping the jack handle firmly under the radiator support.
8' LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect.
CRAFTSMAN 1/2" x 16" SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Detroit, and rounds them off.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
POST MALL: Large sledge used to deform parts enough to fit in spots previously too small to hold them. Also used as a stress reliever much like those little bean bags the office crowd have.
AIR IMPACT WRENCH: A air tool used to: a) tighten wheel nuts to the point where they cannot be removed beside the road in the rain, or: b) a tool for breaking chrome plated hand sockets, or 3) a tool used to launch socket extensions across the garage floor at 40 mph.
<a href="http://www.ucalgary.ca/~csimpson/Tools.html" target="_blank">http://www.ucalgary.ca/~csimpson/Tools.html</a>
So very true... <img border="0" alt="[hiha]" title="" src="graemlins/roflmao.gif" /> <img border="0" alt="[ouch]" title="" src="graemlins/c.gif" /> <img border="0" alt="[hiha]" title="" src="graemlins/roflmao.gif" />
Jane Bond 007
OMG! I had to shut my office door I was laughing so hard. That has got to be the FUNNIEST thing I've read here. Absolutely hysterical
almost better to buy a new engine block at that point <img border="0" title="" alt="[Wink]" src="wink.gif" />
*not that I know* heheh
BAND SAW (with new blade): Will quickly cut through flesh straight to the bone, tearing both your nerve, artery, and tendons!
Happened to my friend's dad while he was helping us build the trebuchet (See other post). In about 30 seconds there was a nice size puddle of blood on the floor and all over the saw. <img border="0" alt="[ouch]" title="" src="graemlins/c.gif" />
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by special tool:
<strong>Peter Egan, right??
<img border="0" alt="[bigbye]" title="" src="graemlins/xyxwave.gif" /> <img border="0" alt="[burnout]" title="" src="graemlins/burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Damned straight!
Many of my friends and I think he should be knighted (especially for his attraction to British bikes and cars). Sir Peter Egan. It just sounds right.
I have to say that he is a major inspiration for me to write. "The Great TC Trek" is by far the best piece of automotive journalism I've ever read and just a damned good read. And I have zero interest in or passion for a MG TC. I'm currently reading the compilation of his columns. Some day I HAVE to meet him.
