When does ABS kick in?
Not Special
So on my morning drive to work I almost bagged a deer. I stood on the brakes, was able to slow down, then move into the other lane to avoid the deer, but it got me wondering...it is wet here in Oregon and while I was in the brakes fairly hard, I didn't feel/hear the ABS kick in. I know some of the racers run with ABS still, does it take more braking than I though to kick it in?
If you didn't lock up, then you didn't reach the abs threshold.
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4-matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
If it was wet you should have locked them up easily. Find a safe spot (empty parking lot) and get on them. Make sure they are engaging. If not, I would get them looked at ASAP....until you do remember you are the ABS and pump!
Not Special
Thanks. Maybe I didn't stand on them as hard as I thought.
