Spacers on my 944 with Fuch's????
I just took my rear wheel off my '84 944 and found a huge spacer. I was surprised to see this. Is this because I am running Fuch's on this car and the offset was different?
If your wheels are "late offset" and they are being used on an "early offset" car, you would need about a 1" spacer to get back to normal. But folks can, and will, put on thicker spacers to increase the track width of the car, which theoretically will yield a small increase in cornering ability. The spacers on the back of my 1985 944, put on by the previous owner and using 968 wheels, are about 2 1/2" thick. There is certainly plenty of room in the rear wheelwell for this arrangement.
It must be an offset thing. My 86 with early offset (23.3 mm) Fuchs had no spacers. As ernie9468 said, late offset (52 mm) would require a spacer to return to early offset, but the big fenders on a 944 mean you can space the wheels off stock by quit a bit. Also note that the driver's side is likely to be spaced outboard by 1/2" relative to the passenger side. This is due to the spring plate cover being attached to the chassis by a bolt in an elongated hole. The bolt apparently ends up toward the outboard side of the slot and the wheel follows.
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4-matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
Not so. The rear wheel on my car was an 8x16 Fuchs part number 951362117. No spacer. Nada. Not a 911 part number. Since it was an option, there weren't many around, and a common substitute was a 911 Fuchs.
See:
http://forums.pelicanparts.com/porsc...rs-offset.html
Regards,
doug
83 944 (sold in 86)
See:
Regards,
doug
83 944 (sold in 86)
[QUOTE=dykaar;8020311]Not so. The rear wheel on my car was an 8x16 Fuchs part number 951362117. No spacer. Nada. Not a 911 part number. Since it was an option, there weren't many around, and a common substitute was a 911 Fuchs.
Don't know about that since like I mention mine came with 16 fuchs & spacer & like ___sdstimson __is saying longer studs.
The steel arm cars from 83-85 used spacers on the rear stock to achieve the standard track width.
The 85.5 and 86 cars using aluminum trailing arms did away with the spacers to achieve the standard track width. I believe the factory spacer is 21 mm, but I could be wrong.
BINGO.
My car is an 86 with Al swing arms, Fuchs and no spacers. Fits the explanation.
Regards,
doug
83 944 (sold in 86)
Regards,
doug
83 944 (sold in 86)
Yeah, I recall my BBS to be a 23mm offset on my early wheels for my 84, and they were the original wheels. The spacers I used to upgrade to late model wheels were pretty big spacers. Been running them with no problems what so ever though.
