MSDS Headers/gaskets
Ready to install MSDS headers on 1989 944 NA. I know that welding needed to connect to cat or straight pipe and that gasket included....I assume that 4 gaskets are needed where headers attach to head??? Does anyone have any experience with this and what material would those gaskets be made of to withstand the heat???? Help anyone. Thanks
I put mine on myself
i used the old gaskets for the head...
i didnt have the welded part welded on...
and if you have plans on jacking the front end up and installing it, make sure you jack up both side or else the motor will be twisted in a way that it wont install
space
space
mine is really loud....with the car at idle, you couldnt even hear my 2 12's out side the car...
mark....i am going to run the 3 inche setup also....did you replace your cat with a highflow? where did you get the midpipe at?
whats your tip look like?
thanks,
space
thanks,
space
Right now i have them angle toward the rear hatch....
there are in the same box but separated in the center....
when i get the car back (if i get the car back), the back seat is coming out and im going to put another 12 in there....
i'll have 2 facing the rear and one facing the front....
i'll try to get some pics for you....try being the key word...
space
space
