feedback: gutting the car
lol
ok, as soon as sun comes out
and that's the filter I got, that part I remember, lol
and, bookmarked!
I don't think I have any vac lines connecting canister to anything anymore, and that vac pump or w/e on passenger's side is disconnected too, so I'm half-way there? lol
and, bookmarked!
wanted to bump, I remember I owe you all pics, I'll take them once I get a few things out of the way
we were able to change and put in a low-temp (71*) thermostat and fan-switch in, trying to bleed the system again right now
it's kinda-sorta raining
I also redid some of the vacuum line stuff and took out canister on the passenger side and hoses going to it - now I have small hose to the brake booster
simplifies things A LOT
lol
lol
lol
lol
the sunroof delete - if its a fiberglass part you are talking about, weighs something really light like a couple of pounds maybe ... stock roof is pretty heavy
not sure if removing the inside panel would do anything
plus, this is one part that I really don't want to do, if I have to, I'll just take the roof off
Why not just gut the roof panel and glass it in? I will sell you the one off my car that was siliconed in REAL CHEAP before I reworked it if that helps you. Have transplanted the parts car roof in already. PM me if you want to go that route.
Fiberglasing is not that hard, reglassing some box rockers I picked up last week as we speak. Just some sanding. prep, and glassing. You can get what you need at Autozone to do the job.
michael
I don't know, I kind of like having the roof I can remove etc
this might be the only thing that I'm not wiling to compromise on, LOL
'bird - question for you - carbon canister is inside the driver's fender well, on the inside under the hood at the same spot - driver's side firewall corner - there are a couple of things with various vac lines going to it and from it - I got everything off, except for 1 line that goes to the J-boot - do I just plug it closed at the J-boot? re-rout it to something else?
I'll finish this weekend
also, apparently, my spark plugs weren't "spaced" right - we just fixed it, and car idles MUCH better now!
thanks! would really like to know so I can finally finish this
my brother said that there are scales somewhere around here (within 2-3 miles) - so we'll probably take the car there and see where it stands at the moment ...
michael
michael
you could also make a negative mold of the entire roof, with the sunroof in place, resmooth the roof to whatever end profile you wanted, then mold it in place of the metal (cut away all the metal) and end up with a FG roof that would look however you wanted it to...
funny thing with FG is the end product will only look as good as the effort put in to make it look good... I have seen great FG work, and shoddy FG work, both starting with the same pieces...
I think I misread or misunderstood glass and fiberglass. I was thinking that a clear glass insert up there would be nice from the inside even if it wasn't great from the outside.
You got that right. Even some of the 1980s Corvettes were full of waves and ripples if you look at their doors from behind. Hot tubs are better made than older Corvette bodies!
ive got a cap on the fitting that comes out of the j boot. you will want to cap this off to prevent a vacuum leak and to prevent unfiltered air from entering the engine.
