944S temp sensor electrical connector location
Old 11-06-2002, 12:28 PM
IPSC
IPSC's Avatar
Post 944S temp sensor electrical connector location
Does anyone know where the electrical connectors are for the temp sensor? I want to ohm out my temp sensor but I can’t seem to find the silly connector / connectors. I have heard that they are somwhere on the fire-wall? Is this correct?
IPSC sends
Old 11-06-2002, 12:34 PM
SoCal Driver
SoCal Driver's Avatar
Post
I would check the temp sender values for the DME at the DME plug.
The gauge temp sender at the block.
Be back in a sec with the pin numbers.
Old 11-06-2002, 12:46 PM
SoCal Driver
Post
Here's a cut from the manual:
Old 11-06-2002, 04:13 PM
IPSC
IPSC's Avatar
Post
Thank you very much that will help. I was hoping someone would know where the connectors are in the engine compartment because I wanted to check them for corrosion as well. I am getting some intermittent jumping in my temp gauge as well as the running hot phenomenon. I “figger’ that I can ohm check and clean the connector to verify the indicating system is good before I start draining coolant... especially since I now have all of the air out of the system.
IPSC sends
Quick Reply: 944S temp sensor electrical connector location
