how its supposed to run?
is this how a 944 should run?
http://www.youtube.com/watch?v=lvmeZ...eature=related
my whole engine torques about 1 1/2" when i turn the throttle cam...this one doesn't seem to move
it depends on how you do the throttle. if you flick it wide open fast, it will most likely move quite a bit, but If you gradually rev it like in the video, it will not move very much at all.
is there any way to test the engine mounts? iv always thought that i messed up the balance shaft timing but i recently discovered how to check to make sure thats good, so once i do that if it still shakes like an orbital sander then its most likely bad mounts?
