My restoration thread
While it may not be as complete as many other member's restorations here, I'm going to use this thread to track my progress and post some questions I have along the way. A little background: I've had the car since I was 16 (23 now), was my daily driver then. When I bought the car I did the w/pump, T/belt, balance belt, rollers, etc. Later when I was 17 I put a clutch in. When I was 19 the Headgasket went and I parked the car. I bought an Explorer and drove that daily while I saved money for the repair. Once I repaired the headgasket, I still only drove the car on weekends. This past October (22) I bought an 07 F150, and in December I sold my Explorer. I'm now at a point in my life where I have the time and resources to put a little toward what I've always wanted, my Porsche. I've neglected it a little the past few years but now I'm starting to bring her back to life. I'm going to try to post pictures weekly so here goes!
Started May 17, 2010 by scheduling her at the body shop. August 23 is the date she will go in for body work and a full respray. Until then I have some mechanical stuff I'm going to do! I pulled off the center caps to restore them. I got them in all silver on the 17th.
![](http://i29.photobucket.com/albums/c274/Awoir/Porsche/May%2017%202010/P5160153.jpg?t=1275002674)
Next post (in a few minutes) will show pictures of the car currently and progess till today (27th).
Planned repairs until the end of the year:
Repaint center caps
New carpet (Ordered)
Frame straightened / passenger rear quarter installed / full respray (Aug 23.)
Motor Mounts
Constant full heat while driving
Removing rear seat
SS Brake Lines
New Shift Boot
New Windshield
New Hatch Seal
New Door Seals
New Shifter Insert
New Fuel Hoses
New Vacuum Hoses
Paint Intake / Cam Tower / Distributor Housing
New Plug Wires
New Brake Master Cylinder
New Coolant Overflow Bottle
Headlight Upgrade
Fog Lights
Snub Bumper
Shave Washers
Repair Sunroof
Paint Calipers
New Hood Liner
Repaint center caps
Motor Mounts
Removing rear seat
SS Brake Lines
New Shift Boot
New Windshield
New Hatch Seal
New Door Seals
New Shifter Insert
New Fuel Hoses
New Vacuum Hoses
New Plug Wires
Headlight Upgrade
Fog Lights
Snub Bumper
Shave Washers
Repair Sunroof
Paint Calipers
New Hood Liner
Rear Seat Gone
![](http://i29.photobucket.com/albums/c274/Awoir/Porsche/May%2027%202010/P5270159.jpg?t=1275007286)
Sunroof - I can open it with my hand at any time, will not latch, and I don't see anything to make it latch. Any tips / ideas?
![](http://i29.photobucket.com/albums/c274/Awoir/Porsche/May%2027%202010/P5270163.jpg?t=1275007280)
Rear Hatch - Two pictures, this hinge (Passenger side, between the top of the hatch and the body, at the top by the roof) the pin that goes through the hinge is gone, no idea where it got to. Can I get a new pin and just reseal my hatch? The car leaks water here.
![](http://i29.photobucket.com/albums/c274/Awoir/Porsche/May%2027%202010/P5270161.jpg?t=1275007281)
![](http://i29.photobucket.com/albums/c274/Awoir/Porsche/May%2027%202010/P5270162.jpg?t=1275007284)
Can't wait to see the final results.
I just had my 944 that I have owned for 23 years repainted. I am currently putting it back together and will post pictures of the beginning until end when I am done.
With the new repainted center caps (Can see in drivers side pics) I might repaint my phonies, but even if I don't the wheels will be re-balanced so the weights go on the inside.
Sunroof - Followed clarks-garage. Switch is good, relay is good, Direction relays are good, but no power to the directional relays, has to be a broken red power wire to them, anyone know a common area they break?
Okay, so I do have 12v to the directional relays, but no resistance reading in the microswitch between the sunvisors (Triangle one). I am assuming that I have to replace the microswitch. Where is a good place to purchase one, and there is no way to bypass it, correct?
Check 944online.com for the switch. Jamie and Ian are really great and customer service is top notch. I had some parts on order that I needed for this weekend and a part that I didn't need was on back order. Jamie hand delivered the parts to me on Saturday (I live a little North of them and he was going to be driving by, so he figured he would drop them off). Great company to deal with!!
