Turbo kit vs Supercharger kit
1 Post
I would like to just find out the difference in supercharger kit and turbocharger kit, in what is the best value for cost and also the difficulty in installing them.
I got 2 NA engines so I was thinking of try and fit one kit to the engine in the car now and see how it works/lasts and find out what went wrong if (when) something goes wrong and fix the problem and install in onto the "new" engine compleatly overhauled. I almost got all the engien parts for the overhaule and will begin it in desember/januar (Going away for 3 months now)
I will upgrade brakes to a big break kit so it can handle the power when stopping.
And install a turbo/s2 tranny and transaxle.
Kits I have found so far I would also like a list from the pro ppl of what parts I need for each system if im gonna shop peace by peace.
Turbo Kit :
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
Supercharger Kit :
http://www.speedforceracing.com/inde...productID=1029
I DO NOT WANT A TURBO ENGINE I WANT TO BUILD MY OWN AND TRY/FAIL
Turbo Kit :
Supercharger Kit :
Captain Obvious
IMO I'd buy used turbo parts for your NA from a good used 951.
The supercharger route is also a good option...at least for the S or S2 it's the better option.
Those ebay knockoff counterfeit turbos are garbage, as mentioned above its a total waste of money.
Do not waste your time with this project.
There are a thousand reasons not to embark on this project, but I think the nail in the coffin is tuning.
Are you willing to go full stand alone and have a professional tuner spend hours with it on the dyno ?$?$? just so it is drivable ? You could use an an FMU (Cartech/BEGI) and get okay results as far as the tuning goes but its not going to be anything near a factory tune.
Turboing an N/A is like trying to build your own UniVac so you can run DOS on it when you can buy a watch for a tenth of the price that runs Windows XP.
Rainman
it comes down to who does the tuning and how the rest of the project is built though, sometimes even the best tune can't save the ****tiest shanghai turbo
Rainman
if you really want to, buy the turbo kit but find a better version of that turbo, an authentic one, and use the chinese one as a desk ornament.
then good luck getting the stuff to work.
1 Post
Well im definitily not going with the china stuff... Im gonna se if i can't find a good used kit for a 944 or something like that. If I can't find that Il have to save up for the supercharger :/
those turbos are held together with GLUE... believe me ive seen it.
if you want a turbo... http://pagparts.com/index.php?cPath=1
If you want a project, get a cheap 951 and get it running.
If you have more cash, get a nice 951, take it apart, and put it back together.
It sounds like you're trying to chop off your foot just so you can try crutches out...
the most important parts of a turbo kit.
1) turbo itself
2) turbo manifold
3) the intercooler design
that kit doesn't even HAVE a manifold.
you should not start a project by "what do i need to buy"
if u want to learn how to turbo an NA car, start with reading. understand forced induction with a turbocharger. how to read a boost map. how to calculate the optimal housing, turbine and compressor wheel sizes for your engine. different styles of turbo manifolds and effects of their different designs. internal vs external wastegate designs. side flow vs top flow intercoolers. effect of intercooler piping diameter. purpose of a BOV. recirc vs atmospheric venting. tuning AF and spoolup ignition characteristics.
once u've understood all of those topics and more, then u can start BUILDING a turbo from your NA. i won't cause i don't understand it all myself. but at least i'm aware of them.
1) turbo itself
2) turbo manifold
1 Post
Getting the "hard parts" ie turbo, exhaust manifold, intercooler, is actually the easy part. Custom fabrication of intercooler piping, is a bit more complicated, and requires skill to weld up the piping. It is a tight fit at best.
Bigger injectors, fuel pump, and some extra sensors take some research as matching parts to work correctly (ie low/high impedence injectors)
As for controlling all of this. Standalone is the only proper way. Piggyback systems, and controllers that "trick" your stock ecu are a waste of effort.
Research Megasquirt fuel injection. I paid $700 usd for the complete kit (sensors, harness, relay board, ecu assembled) Less than 20 wires if I recall. It does take some understanding of engines/turbo's, and some research for specs of your engine, but it can work extremely well.
I can adjust mine with a simple click of a button on my laptop. It even has some "autotune" functions to make the car driveable, then it just takes time to drive/datalog, and analyze, and tweak...over and over and over until it is tuned to YOUR driving style. A decent shop could get you 90% tuned in a matter of a couple of hours on a dyno.
Mine starts, idles, crusies better than it did with the 30yr old Bosch EFI system, and I am putting down 3 times the hp over stock.
(Not a Porsche. This is on my turbo'd Datsun 280Z) but it is not that different.
