944 V8 video...new exhaust!
Just finished building a new exhaust for the beast. It's a dual 3 inch mandrel bent aluminumized steel system that runs all the way out, through a home-made x-pipe, to two flowmaster 50 series delta flow mufflers...sounds alright huh?
yeah, i ran it side by side all the way to the front of the transmission, then i ran out of room to go side by side, so i ran over under, it's worked nicely so far!\
at first i was a little worried about the look of it, but it's really starting to grow on me
Ethan maybe have the two 3' s connect into a y pipe that runs into a 4" or 5" muffler?
Sounds great btw. How does it drive since the change?
I have a feeling it looks better in person.
the old exhaust was actually lower than this one by about 3/4 of an inch, and it made it a whole year of driving over really crappy driveways without ripping it off
It's driving pretty nicely, definitely has some power in it...i'm considering putting in a pair of thrush glasspacks in where the old cat was to bring the volume and resonance down a bit.
i wouldn't say that it looks ghetto in person, just very unique, i did the install as cleanly as i could, and it looks a lot lower than it really is because the rear wheels are sitting in a ditch...here are some pictures from when i first finished it.
haha, i've thought about something like that...i'll probably eventually put a fuel safe tank in the back and remove the old gas tank, then run one pipe over to the opposite side, probably do a single in dual out muffler on each side, flipped 90 degrees and tucked up, maybe with one pipe exiting through a cutout in the bottom of the bumper, that will look a lot like that lexus, or a TVR
