Today's increment: rear wing uprights simulated
Small incremental progress on mounting the rear wing. I suspended it, in the proper position, so that the wing is gonna be far enough back so the hatch opens. pics at:
http://www.pcaucr.org/index.php/visu...egory&catid=61
I decided to have a steel assembly fabricated that will sit on the frame and bolt to the wing mount through drilled out license plate mounting holes. The load will go through the assembly onto both the frame where the bumper is mounted and the hoop that the rear hatch latches onto. That was clear, eh?
Next is to mock up that assembly in foam, take some pix, and find a good welder in the neighborhood...
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (http://www.pcaucr.org/index.php/visu...egory&catid=61)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http:// http://www.trillium-bmwclub.ca/forum...sp?postid=1916)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
