Momo Seat Install
well your talking about 2 different things with sliders and mounts. The universal mounts may work with some custom drilling. basically drill some holes in the floor and bolt the seat in. However if your looking for a straight up bolt in mount with no custom work i believe recaro makes one that fits our car.
you will need an adapter to mount the sparco sliders to the floor (floor mounts are 16" wide, but the slider mounting points are 14" wide), but I think that the sliders should mount directly to the seat. I have Momo RS-GT seats in my car and that's how they're mounted (floor -> adapters -> sparco sliders -> seat).
sparco tracks mounted directly to my momo seats. They did not mount to the floor. In order to mount them to the floor you need a wedge bracket. speedware, paragon, etc. sell the bracket for about a hundred bucks a seat.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
one additional option is to simply use the stock sliders..
first, you'll need to get them flat - (by stripping any excess sheet metal off)...
if the bolt pattern is the same as Sparco, and it probably is, then, you'll need to add new sheet metal to them where your new holes will need to go... (thats going to be just a about 5-6 mm inside of the stock rails.)... careful measuring, welding and drill. 3/4" ~ 1" tubing will be required as an insert to raise the seats so they'll clear the levers on the sliders. they'll also be at the proper height.
that's how i got a perfect fit using oem sliders off my 968 to install my Sparcos.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
https://rennlist.com/forums/924-931-...eir-944-a.html
