Spacers or Fake Fuchs?
oh that is so sweet! i think i might have to do that. what width tyres (tires) are you running with 8's and 9's? I'm early offset though, what would I need to run them?
i have 16 x 8's with 225's on the back. when I need new tyres I might get 9's and put the 8's on the front.
I just polished mine today which made me think of this thread.
![](http://img822.imageshack.us/img822/9900/dsc04386copy.th.jpg)
![](http://img822.imageshack.us/img822/7054/dsc04377copy.th.jpg)
I've got 7mm spacers on the front of my car, but that is so that the wheel clears the bleeder valves on the 928S4 calipers.
Will any 930 Fuchs 16 x 9" wheel fit the 1986 951? I'm wondering if the late 930's had ABS issues that affected offset as on our 944 Turbos. By the way; the wheels look great.
Thanks!
There is only one 930 16X9 Fuchs part#. To my knowledge all 930 16X9 Fuchs are the same and will fit all 86 951 cars.
951 8's have a 23mm offset.
911 8's have a 10.5 (or so) offset
930 9s have a 15mm offset.
so, if you put a 17m spacer on the rear, and run your 951 8s' you've essentially got 23+17 = 40mm offset. Which is not much less than the "late" car's 52ish offset. What I am not sure of if there is enough room in the rear fenders to run such a large spacer, but it seems like there should be.
What size tires are you currently running? 205/225? If so, you could help fill the fenders by running a 225/245 tire combo.
Yes, that's what I thought too although I wasn't really measuring in terms of offset, but rather how much the track would increase. When I measured from the outermost portion of the tire, I calculated that I would clear the wheel well lip by a few millimeters. My main concern with spacers is that the 225 tires might look too narrow when spaced-out like that. Plus as Tifo pointed out, the deep, angled dish of the 930 Fuchs won't be there to pull-off the look. This is an instance where I agree with nearly every opinion I've read in one aspect or the other. Until I'm sure, I'll probably hold-off but continue to obsess over it. Thanks everyone.
