Karl Poetl in the Racer's Edge 944 at Watkins Glen
No accusation. It's racing. Tapping the brakes at the start, or slightly holding back is a common thing. So much so that anyone behind you will stab the throttle if they see brakelights-thats the danger.
Man, that is the the best 15 seconds I've seen in a while. Dude's got some ***** regardless.
I didn't mean to sound contrary.
The video is from a fellow 'lister named Sean. It was from the Watkins Glen race last weekend.
I doubt Karl hit the brakes at the race start. It's the responsibility of the pole setters to maintain a steady speed until they see the green flag - but people behind the pole are always eager to jump the start a little bit. I'd say he might have just been a split second slower getting on the gas.
I've run with Karl at other races, and the first time I met him, I was impressed that he had about 30 different spring sets in his trailer, and he'd be swapping them between practice sessions to find the best combination. I'd also imagine that he's had that car on the 7-post shaker - like his 996:
Is there any more video? That one runs out way too quickly.
Weird rule about the variance in tyre size too? They must assume the turbo guys are cheating so penalise them first. Sort of guilty till proved innocent...but we've made the rules so go away now forced induction guy....
The ironic thing in all of this? Karl has petitioned PCA to allow the turbos to run the same size wheels and tires, because he thinks it will make better racing.
Without a doubt, when active guys like this get involved, it's better for all of us. Especially the fact that Racers Edge is out there on the track instead of just crafting big ads for the magazines.
I love their stuff myself.
I love their stuff, too. I'll be talking to him soon about a cage, as well.
Rules are that you can run wheel width of what was available as OEM +1 inch. M030 Turbos had, to my knowledge anyway, 7's and 8's (Turbo S had 9's in the rears, but 7's up front - and they are F-stock anyway). However, the S2 with the M030 package had 7.5's and 9's. The S2 also had the bigger brakes, if I am not mistaken.
I actually had my guards rolled yesterday on my '86 turbo. I run 10"x18" all round but wanted to lower the car. Now that we've fitted some of Karl's camber plates I can lower the car again without losing free travel of the front struts. Yay! Should make things a lot better than here where the car held it's own against a rather fancy RS...as well as 2nd gear syncro and a few other issues
http://www.youtube.com/watch?v=YX99Ac_Yie4
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
car is for sale ?
That's a pretty bold accusation. Find me someone who has raced against him who will make that accusation and get back to me. Until then, watch the video, and note how much later he brakes than everyone, and how deep he brakes. He is fastest through the turns, not the straights. I can't find any reason he'd sandbag from teh start when he is sitting out front, anyway.
didn't notice him braking at all
btw, is it a malfunction on my computer or is the car for sale ?
http://www.racersedge-inc.com/racers...A00740BB3?Open
I always thought all the turbos came with 7.5"s and 9"s regardless of vintage. They have different offset suspension/wheels but the size of the wheels were the same. The early model turbos had a smaller caliper than the S versions. My S had what we call 'Medium Blacks'. Same as a 928 S4 and also the 944 S2...so I still don't get the disparity in your race rules?
This is straying somewhat off topic, as Karl's S2 is in SP3 class, no
longer a stock E or progressed F car per PCA Club Racing Stock Class
Rules.
Having raced an E class (former F class) 87 951 for several years:
The k26/6 951s came with 7s and 8s, so can only run 8s and 9s per PCA Club
Racing Stock Class Rules.
As mentioned, S2s (with the M030 option) came with 7.5s and 9s, so can run
8.5s and 10s.
The two big differences between the S2s and regular Turbos (for PCA E
Stock) is the 15% shorter S2 gearing (3.875 r/p), and the M030/Turbo S
brakes are allowed on the S2s. The wheel size also can give some
advantage to the S2, because its not ideal to fit a 285/30/18 tire on a 9"
rim. A 275/40/17 fits on a 9 ok - but again the problem is that it
increases the final drive which is already too tall on the 951s.
Advantages do vary somewhat track to track (long/short/high speed/hard
braking, etc).
Powerwise, a legal 951 can still pull a legal S2 on long straights. But
dont assume all front running cars in any class are 100% legal.
The 3.0 16v motor and even the 964 3.6 motor does not make more mid range
torque than a 951 - on the track (if you ever are below 3500-4k rpm in any
corner, you missed a downshift). Peak torques are lower (ft-lbs) and at a
higher rpm than the 951. Even with the taller gearing, a 951 can nearly
stay with an S2 out of a corner, and can actually gain some ground on a
964 (964s have slightly taller gearing than 951s). But the 964s will
start walking away from a 951 further down the straights, at higher rpm.
It's a cat and mouse game with an S2, due to the shift points. The
shorter the track, the S2 will have a greater advantage.
Neither the S2 nor the 951 are competitive against the Euro spec SC in E.
The K26/8 Turbo S cars are very competitive in F, as is the 964 C2. But
possibly the best car for F is a progressed K26/6 951. Can run with the
S2 R/P, big brakes, big wheels, and DME chip and weighs 100+ lbs less than
the Turbo S and 964 C2.
Good racing and neat video.
No accusation of any kind? Earlier you claimed that sandbagging is dangerous. Now you are claiming he is holding back. Um......not sure what you are saying, but it looks to me like you are making a pretty big accusation that he is sandbagging, and thereby creating a dangerous situation. Whether or not you or anyone else has a problem with that is neither here nor there, but it reads to me like you are accusing him of sand bagging. And I'm calling BS on you.
