cant get head gasket residue off block, need help soon
thanks (now i need it to run as good as it looks)
update:
drove the car home (60 miles)
the first 15-20 went GREAT other than the poor idle it ran great. the rest of the trip it stumbled some and when i got home it sounded like it was missing when it idled.
its done this twice before in pouring rain but ive never been able to locate it. today was sunny and dry but the car did sit through several thunderstorms.
edit:
i should also mention that when the car is not stumbling, it feels smoother than it ever has. i have zero vibration at 6000rpm
maybe i should also note the gas gauge is WAY off too. it was on empty when i fired it up, i filled it, and it only went to a half tank. (ive never seen it do this) probably unrelated, but its worth mentioning.
edit:
hypothetically speaking, if the sender and fuel pump use the same ground could this be both my gauge and running issues?
edit:
for searching issues in the future, lets consolidate this issue to this thread:
https://rennlist.com/forums/924-931-...y-problem.html
i appreciate all the help
