I need to pull out the cylinder 1 and 4 manifold. Do I have to remove both manifolds to do this? Clark's says that the studs have to come out and the water line return has to be disconnected. Will this hold true for the removal of just the 1 manifold? I have a nasty crack that needs to be welded.
I was able to pull mine with no problem. I had the same crack in mine... replaced them with the msds headers instead of fixing the crack though. They slid right in as well.
