What broke???
Old 05-27-2010, 04:28 PM
T_Glass_27
T_Glass_27's Avatar
Default What broke???
I was driving today and shifted into 2nd gear at 3500 and heard a loud pop. The car will go into every gear as smooth as butter but when I come off the clutch the car doesnt move as if it in neutral. What broke?
Old 05-27-2010, 04:30 PM
krystar
krystar's Avatar
rubber center clutch
cv
halfshaft
ring/pinion
stub axle
Old 05-27-2010, 04:37 PM
T_Glass_27
T_Glass_27's Avatar
Brand new clutch, only 3,000 on it. Spring center sachs. CVs look good.
Old 05-27-2010, 05:04 PM
Lemming
Lemming's Avatar
Half shaft
Old 05-27-2010, 05:06 PM
T_Glass_27
T_Glass_27's Avatar
Any idea where I can get one? Anyone replaced one before? Is it a pain?
Old 05-27-2010, 05:10 PM
Lemming
Lemming's Avatar
You need to make sure that that is what broke.
Old 05-27-2010, 05:25 PM
JimV8
JimV8's Avatar
Whatever it is. It's serious.
Old 05-27-2010, 05:29 PM
whalebird
whalebird's Avatar
with a recent clutch job - take it back to who did the clutch. Maybe the coupler in the TT.
For the halfshaft, when in gear and running, see if one of the axles is turning. Get some help with this from a buddy or bridely assistant.
Old 05-27-2010, 05:36 PM
Keaton944
Keaton944's Avatar
what does it sound like when its in gear and you left off the clutch? Can you hear a squeal type noise or sounds of anything rotating back there? Mine acted this way when the teeth on the end of the driveshaft worn down but you could hear it spinning back there. Could also be throwback bearing in the transmission i guess but im pretty sure that would make a squeal type noise too, like a spun out noise of metal spinning on metal.
Old 05-27-2010, 05:38 PM
T_Glass_27
T_Glass_27's Avatar
We have a winner, The CV looked good earlier when I peaked under waiting for the tow truck. Its home now and I jacked it up, grabbed the half shaft and it fell right off.
Old 05-27-2010, 05:48 PM
Potomac-Greg
Potomac-Greg's Avatar
So the rubber boot was your CV joint!?
Luckily, it's not a big or difficult job.
Old 05-27-2010, 06:11 PM
T_Glass_27
T_Glass_27's Avatar
ha yep, the rubber cant handle the torque unfortunately
Old 05-27-2010, 06:16 PM
krystar
krystar's Avatar
wow.
Old 05-28-2010, 04:30 PM
Don 944 LA
Don 944 LA's Avatar
sounds very familiar
https://rennlist.com/forums/924-931-...w-fd-am-i.html
I've also had a CV just spin freely, a halfshaft grenade, transmission grenade..... face it I'm hard on transaxles, replaced like 4 so far
Old 05-28-2010, 05:03 PM
dillon410021
dillon410021's Avatar
I would rather snap an axle than the trans, clutch, or T.T.
Quick Reply: What broke???
