Oil drain plug is missing the washer... a little help?
Ok my car has been leaking oil out of the drain pan for quite some time at first I was worried, but after watching things I guessed that the oil was coming from the drain plug.
I went to change the oil today and to see what the problem was with the drain plug, well I get it out and there is no washer. Correct me if i'm wrong but there should be a washer here correct?
My question is where can I get a new one?
Ian,
First, be sure you are actually missing the washer. Sometimes it gets stuck on the pan. Look closely. Second, I can bring over one of my spare washers tomorrow if you need one. Let me know.
Dave
Dave
Big thirst, Sore Thumbs
Napoleon
Napoleon
Funny story. I had a POS Jetts for about two weeks. I went to change the oil. Couldn't find the drain plug. Where I would suspect it should be was a little Rubber Button. "AHHHHH!!!! The drain plug is probably under that Rubber button. Those German are so great. Making a little rubber button to protect the drain plug."
So I proceeded to remove the button while laying directly under it and with no drain pan handy.
It was the drain plug and I got a face full of used engine oil.
[quote] Some places provide the new washer with each new filter they sell - so you don't have to remember <hr></blockquote>
Is this something new, as I have never received a washer with an oil filter and I only buy from one place
Never the less, an old one can be reused with no problems.
By chance that wouldn't be Paragon Products, would it?
[quote]Originally posted by SidViscous:
[QB]Where I would suspect it should be was a little Rubber Button. "AHHHHH!!!! The drain plug is probably under that Rubber button. Those German are so great. Making a little rubber button to protect the drain plug."
QB]<hr></blockquote>
That can't be stock, can it? You can buy expanding rubber plugs to fit drain holes with stripped threads. Used them myself.
[quote]Originally posted by Skip:
<strong>Some places provide the new washer with each new filter they sell - so you don't have to remember
S</strong><hr></blockquote>
Hey then how come I was charged .40 cents a washer and had to order them seperately?
Napoleon
Napoleon
Probably was aftermarket. I wasn't saying the Chermans had designed it. Was saying my thoughts as I pulled it out.
I'm not that bright in case you couldn't tell.
I understood that, I was just using your quote to refer to the plug.
You guys that say you aren't bright are the dangerous ones. Whenever a reporter says that, the hairs on the back of my neck stand up.
