how effective actually is the front bumper
Rainman
wondering what people's experiences have been over the years with crashes etc with regards to the actual effectiveness of the front panzer bumper. its supposed to be a 5mph bumper but how often do you hit things at that speed...
I've heard that offset hits cause the bumper mounts to bend/tear the frame. Some 944 racers actually modify the bumpers so the mounts break rather than transfer the blow to the frame.
I also saw car to car contact where the 944 front bumper works a battering ram. It crushes the other car while only pressing in the bumper shocks.
In gentle impact it helps reduce frame damage.
In a medium offset impact it can twist the bumper shocks damaging the front frame.
In a hard impact it will distribute load from one side to the other frame rails this allowing each to deform less while absobing the same loads.
So 2 of 3 cases it nice benefit. Plus the bumper work great for a tow point and even can be used the lift the entire front end of the car if needed.
A few years ago I hit a concrete wall at about 25 mph. Hit occurred on the front right of the bumper. Both frame rails were bent towards the driver's side about 3 inches but suspension points were not moved. Tied it to a tree and jerked it straight
Rainman
just tied it and reversed? lol
starting to sound like the bumper/shocks are only really useful in a head-on crash, from the side or an angle they cause more damage than they prevent?
Former Vendor
elzer, you're lucky. On the street nowadays, they're pretty much useless, as just about everything you will smack head on or in a front-to-rear collision is going to go over the bumper anyway.
Rainman
think like a collapsible sheetmetal bracket like the euro bumpers use would be better? probably would do a better job of absorbing a crash, wouldnt tweak the frame (probably bend or shear) and would weigh nearly nothing
In anothe case one driver got spun around and hit a wall a 90 MPH. However due to spin he did not hit at 90 mph directly. It was more of glancing blow and the car was going about 90 when it got turn sideways and then nosed into the wall, but at that speed alot of bad things can happen. Bend the frame. I could not tell if it was bend past shock towers, but it appered so.
Another... Street wreck offset-head on a withe chevy pickup. Drivers side hit hard and severely bent tub. Bot frame rails bent and pass compartment got a litttle tweaked. However driver with 3pt belts un hurt.
5pm impacts may seem rare, but on track 5-10 mph impacts are pretty east to do. Just consided the lead car car slowing from 70 to 60 mph and ctching out he trailing car.. Whack....
Former Vendor
My point was unless you hit another 924/944, the bumper is probably below the bumper of a modern car. The type of bumper shock you have is irrelevant because the bumper won't take the collision, your header panel or rear taillight panel will take the brunt of the hit. I've seen it more than once.
I have no qualms getting rid of the ugly US bumper shocks, whether collapsing them or switching to a Euro style. A good insurance policy is all I need for peace of mind.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I've t-boned another vehicle at a fairly low speed in a 968 on the street (maybe 30mph?) -- impact bent the frame on both sides pretty good....
