Its time to play name that part !
well the late cars shared the brake pad sensor and abs through that plug- if you had abs i guess there would be two wires in there instead of just the one.
Ok thanks reason Im asking is because the wiring loom is splitting and exposing the wires inside, so I want to replace the entire wiring harness. Know of a part number for this ?
I used this special electricians tape.
Scotch 2242 Linerless Electrical Rubber Tape
I removed the broken down cover and then wrapped the wire bundle with this tape.
The trick to this tape is to stretch it as you wrap, once on it stays on and looks good. Worth a try.
If you would rather a new cable this might be it
Pelican Parts
OEM-94461210700 Genuine Porsche Part: BRAKE WEAR HARNESS
- This is a special-order, non-returnable, Porsche part $102.50
Pelican Parts
I'm about 99% sure that its an airbag sensor. Its right below the windshield when you pop open the hood correct?
