I need help with control arm bushing install
Old 03-30-2010, 06:27 PM
arthropraxis
arthropraxis's Avatar
Default I need help with control arm bushing install
I broke a vise trying to get the front control arm bushings pressed in. A friend of mine is using a hydrolic press to get it in. The fronts both went in at 2 tons but the backs are getting stuck at half way in and at 10 tons of force. I need to know if this is normal or am I going to crush the arm before he goes any higher. TIA
Old 03-30-2010, 06:30 PM
Mike1982
Mike1982's Avatar
Which control arms are you installing new bushings on? Steel arms? When I replaced mine on my steel arms, I put the bushings in the freezer for a couple of days before hand and used a LOT of soap/water to get them to slide in. It wasn't easy but just took some time.
Old 03-30-2010, 07:03 PM
arthropraxis
These are for an 87 turbo front control arm bushings.
Old 03-30-2010, 07:35 PM
ritzblitz
ritzblitz's Avatar
I had to use a press to install my front bushings.
Old 03-30-2010, 07:43 PM
arthropraxis
Any idea how many tons of force it took? They are up to 10 tons and one of them is not budging.
Old 03-30-2010, 07:51 PM
catamax944
catamax944's Avatar
stock or weltmeister? if weltmeister did you remove the steel inserts?
Old 03-30-2010, 08:03 PM
arthropraxis
They are stock and I did remove the factory steel sleeve.
Old 03-30-2010, 08:15 PM
ritzblitz
ritzblitz's Avatar
Mine are the early ones, not sure how different the design is on the late ones. We just used lots of wd40 and they slid in without any problem.
Old 03-30-2010, 08:27 PM
arthropraxis
I don't know about the design but they are aluminum.
Old 03-30-2010, 08:36 PM
Grandpa#3
Grandpa#3's Avatar
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
Freezing the bushings and KY Jelly worked wonders putting mine in just using a HD 6" vise and a cheater bar.
Cheers,
Larry
Old 03-30-2010, 08:41 PM
arthropraxis
I broke a 4 inch bench vise and bent the bar on the new 6 inch. I don't guess spraying WD40 or pouring some oil on it would hurt. The problem is it is stuck half way in so I don't think any would get between the liner and the arm.
Old 03-30-2010, 08:57 PM
ritzblitz
ritzblitz's Avatar
Get better vises. Spraying WD40 will do wonders for you. It makes a huge difference. WD40 should be able to penetrate it somewhat. At least try it out.
I think most new vises will break in this situation, they don't make them like they used to, and the ones that come close are very expensive.
Old 03-30-2010, 09:30 PM
arthropraxis
I just talked to the guy trying to press them in. He said they did spray WD40 on it and it still wont press in. They quit at 15 tons for fear of breaking something. I suggested soaking it in oil for a while and trying again in the morning. I do have one in each arm that is seated.
Old 03-31-2010, 01:30 PM
StoogeMoe
StoogeMoe's Avatar
I personally wouldn't use oil on rubber bushings. Oil tends to make rubber swell and may deteriorate the bushing. Use soap or a silicon based lubricant instead.
Old 03-31-2010, 01:50 PM
whalebird
whalebird's Avatar
Try the silicon tune-up grease from any parts store. It works wonders.
Quick Reply: I need help with control arm bushing install
