Potential Fire Hazard?
my 83 944 is leaking oil onto the exhaust manifold and after a couple min of running it starts to smoke and smell bad. im assuming its the valve cover gasket? this a common problem? also how long does it take for new timing and balance shaft belts to stop whining? all responses appreciated
u prob tightened the belt too much. quick check is to twist the belt. timing belt should be twistable to 90degrees, balance shaft belt should be twistable to 180degrees. but that's sort of subjective. u need the specialty gauge to be absolutely sure
The twist method can get you in the ballpark, but it isn't the best method for final tension. There are a variety of belt tensioners out there, but the most favorite tends to be the Arnnworx set. I use them and have never had an issue.
Belt wine usually comes from overtightening the balance shaft belt. When properly tensioned it will seem to be "too" loose.
