How to Smoke Lights
How to Smoke Lights
I've decided to go for a blackout effect on the S2. I plan on smoking the tail lights, front and side reflectors. Has anyone else done this before? How would you go about doing it?
http://www.lamin-x.com/One-Universal...r-p/1-1224.htm
my friend bought a bulk roll, and used it to blackout his tail lights on his 240, and 335i. ill see if i can ask him for photos
So you want to make your car extra hard to see, and reduce brake light intensity? I've never understood this "look", then again I don't get "drifting" either.... but I haven't been rear-ended.
Cheapway....vht nite shades translucent black spray paint
easy way...Craigslist. There are a ton of guys doing this....and there is something to be said for experience....and once you throw in time and materials.... $100-150 doesnt sound bad (the quotes I got for mine included everything but the headlights)
hardway....do it yourself
Remove the lenses. (id get a junk lens to practice on....Im told you should do all your lenses together as a batch for more uniformity in appearance.)
Clean thoroughly.
Ive heard use of adhesion promoters, Ive heard of lenses being sanded, Ive even heard a guy that etches the surface with glass beads and an air eraser....your call.
Once youve done whatever surface prep you intend to....
Translucent Black Paint. Avoid spray paint can materials....its better to use an HVLP detailing gun...
let dry
test light transmissivity and appearance
repeat if necessary
wetsand 2k+
Clear coat.
lucky way....stumble across a set that have already been smoked or were made that way...and buy them.
Upgrading bulb brightness isnt a bad idea....at the very least you should check that your lights are visible from beyond whatever your areas laws dictate as smoked lenses attract the smokies
Clean thoroughly.
let dry
repeat if necessary
wetsand 2k+
Clear coat.
I would say you could do it yourself. I got some red ting for my tail lights of ebay..think metrostyling ..and it came with instructions, squegee, and and you can buy good size cuts of film ($8). See a thread I just put up. I have no artistic/steady apply ability and was able to get it down with Hairdryer, then a small (less then teaspoon) of baby shampoo mixed in water bottle.
I would recommend the film tint over spraying...you can always remove the film and it is a lot easier to do.
They have smoke film too.
1 Post
https://rennlist.com/forums/showthre...ferrerid=75046
Cheers,
Sid.
1 Post
whoopsss that's the wrong one...
Here's the right one!
I did the VHT Niteshades on mine. Works fine, no need to spend $100 when you can spend like what, $7 on a can at Autozone and do it yourself. If you don't like it, wetsand it all off!
I purchased a couple of 20% smoked film overlays on eBay for $14. I applied them myself yesterday. The overall result came out pretty nicely, I think. I will be ordering some more film to redo one light, as I accidentally made a crease in the film. Good thing it's cheap.
I would have gone for painted, but I wanted something that was less permanent. The film can be removed with little pain, if need be. Right now I'm waiting for it to fully cure. Once the weather clears up, I'll post pics.
I hope you drive carefully. It was only last week I was following a van with smoked lights - could barely see the indicators in the daylight.
It's a bit too 1980's Knight Rider for my taste.
