whats the tension on power steering & alt belts
I did my timing and balance belts for the first time the other day. I just tightened the alternator and power steering belts till they seemed reasonable. What should the actual tension be??
According to shop manual... For 944 (Don't have turbo supplement - don't know if it's different)
Alt-A/C belt: 9.5 on the 9201 tool then increase tension one turn on connecting rod. (If no A/C then just 9.5)
P.S. belt: 9201 not needed. Press in center of belt span. Deflection should be approx 5mm.
HTH
HTH
How do you tension the A/C-Alt belt without the $5000 magic 9201 tool. What is the approx deflection tension on the alt-a/c belt if it were at 9.5 on the 9201 tool.
85 lbs - or, about 1/2" of deflection pushing (very subjective). The Kriket I (NAPA, others) is good for this. I always use the spec of "tight"... very scientific, wouldn't care to explain it to you heathens
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Skip:
<strong>85 lbs - or, about 1/2" of deflection pushing (very subjective). The Kriket I (NAPA, others) is good for this. I always use the spec of "tight"... very scientific, wouldn't care to explain it to you heathens </strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Heathens... one of my favorite words.
I agree. Tight is good. I guess it's one of those things that you'll know it. Plus if you're unsure about over tighting then go easy. You can always go tighter if your power stearing or a/c doesn't work.
So, you're saying it's better to be loose than tight? Is that what you are saying? I'm just curious to know if that's what you are saying. Well, is it?
<img border="0" alt="[oops]" title="" src="graemlins/oops.gif" />
Seriously (no, really), loose is better than tight. Loose will give you squeal and belt fraying - Tight will cause excessive wear on the bearings for the accessories.
Skip
Skip
Well, I can tell you what happens if it is too loose. No one had responded in time to my post and I had to get the car back on the road to get home from my moms. So, I put the belt on and tightened it till I thought it was pretty tight. I drove about 3 miles and the a/c went warm and the voltage guage dropped and the light came on. I knew I had just thrown the brand new belt I put on. It wasn't tight enough, so it threw the new one and chewed it to pieces. When I finally found another parts store that had one in stock I put it on and really tightened this one good. I have a little less than 1/2" of deflection but more than a 1/4" between the crank pulley and a/c pulley. I can twist it past 45 degrees but not to 90 at this same location. It did not throw this one. Does it sound like I might have it too tight, or just right.
