Lindsey Ultra Mount with Solid Tranny Mount
I currently have a solid tranny mount and am looking to go to the Lindsey Ultra mount up front. Good idea or bad idea? Does the Ultra mount up front provide enough dampening or should I just replace with OEM? Also would lowering the motor with the adjustability put too much stress on the torque tube due to the solid mount in the rear?
BTW, this is for a race car not a street car.
Brian
Brian
OH Come on!...
No worries over the stress placed on the torque tube, as it will pass any stress to the trans support cross member, if worried about that, you could shim the solid trans mount to compensate for the small angle difference at the cross member...
Herr Unmöglich
I currently have ALL solid, front and back. What I did determine was that lowering the motor did make the trans a little harder to line up with the motor locked down in front.
I too am going to go to the ultra mounts up front I think. I did have a bit of vibration issues but I don't know for sure whether the new motor is potentially a bit off balance. This year I will be trying a known good stock motor so I'll see for sure.
I broke two exhaust systems this year that I believe was due to the vibration. Again, not sure the exact source and I'll be troubleshooting this spring.
Herr Unmöglich
When I broke the exhausts I still had balance shafts hooked up. I have done belts many times now and triple checked the alignments of the pulleys, etc.
I then went to a fordahl header and exhaust setup, and ran several events but still had a ton of vibration, particularly at high RPMS. I also tried running the engine with no balance belts with no change. I cracked a fuel rail even, so it is something I have got to get figured out. The motor was built freshly by a machine shop but had tons of work done to it. Balancing, crank polish and cross drill, etc.
As I said, when my winter mods begin in a couple weeks I will do a motor swap to a factory motor with a refresh. At that time I will install the ultra mounts. If that doesn't work I might swap the trans mount out for something else too.
Ah, the fun of race cars!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Ah, the fun of race cars!![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Your exhaust, did the original have the expansion joints, and does your new one have them?
Herr Unmöglich
I am open to that but the torque tube was fine the year before so unless something happened to it... Flywheel and clutch were pretty new and reused from the previous motor as well. Clutch actually went bad the end of the year so I'll have a new Fordahl clutch and flywheel setup this winter. Trans was also freshly rebuilt last winter. Maybe as the OP states, the weird pressure of lowering the motor with all solid mounts is causing some stress in the TT.
That's where I am at... chasing everything that could be or have been done wrong. I am not giving up on that motor for sure... too much money in it. Just using stuff I have access to in order to narrow down the options. Luckily that includes spare engines are just hanging around![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
So back to the OP's question, I don't think it would be a problem if everything else was in good shape. Perhaps the geometry could be a concern, but that's what we get when doing this sort of stuff I guess. I have noticed that Lindsey also now offers an Ultra Trans Mount too.
Not Special
Hmmmm, looks like I need to go set a few weekends aside soon to get started on der schwankmobile.
To the OP, I'm still not sure what the issue with Eric's vibration issue is. We've got some ideas but certainly with solid everything the car is MUCH stiffer and shakey than it was previously. Hell just driving it around in the pits about shook my teeth out.
I run Supermounts (pretty much the same as Ultramounts but with out the height adjustability) with a solid mount in the rear on my racecar and it is fine. Not much vibration at all.
