oil pickup tube seal
While putting my engine together I realized I need the seal ring for the oil pickup tube. $10 from the dealer or $6.25 from pelican plus $5 shipping.
I know I'm a cheap sob but $10 seems like a lot for a piece of rubber.
Anyone know where I can find it for less?
Geaux Tigers!
Go dealer AND make sure you get the correct seal; i.e. there are a couple different iterations of that seal. Someone can probably correct me if I'm wrong but I seem to remember a black seal, a orange/red seal and maybe even a clear seal in my package when I did this job.
EDIT: Found a picture from when I asked about this seal. Note that mine was for a 951 but this picture shows you all 3 variations of the same seal. I was told that they were not interchangeble.
![](http://forums.rennlist.com/upload/oilpickupseals_003_copy2.jpg)
My gasket kit contains a black, orange, and clear seal. The black one was the correct diameter, but it was tall. It is installed right now, but the flat area on the pick up tube is about 2 mm away from the block and the seal is squishing out.
![](https://lh4.ggpht.com/_Q1elv8ZTl78/S0VgD60LgZI/AAAAAAAABdM/ICvye8QX3Jk/s400/photo.jpg)
That's not right... is it? I assumed I used the wrong seal.
Last edited by jdgunn; 01-07-2010 at 12:23 AM. Reason: added awesome cell phone pic
That's not good. That was the only seal that had the correct I.D.?
I am also a cheap SOB but when it comes to the one single seal that allows for proper oil pressure, I would gladly spend $10 for that peace of mind.
I ran into this and as memory serves me that seal was for a tube in the oil cooler. It fit the tube but was too tall and squishing out.
Seal for oil pickup tube:
http://www.944online.com/cgi-bin/ASI...ystem-944turbo
Seals for oil cooler:
http://www.944online.com/cgi-bin/ASI...oilsystem-9442
