Removing/reinstalling leather seat cover
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
So: What is the procedure to strip the leather cover off a seat, do a repair to some stitching that has separated, and then getting the repaired seat leather back on the seat? Has anyone done this?
A local leather upholsterer quoted me $200 to remove the seat cover, do the repair, and reinstall. I suspect given the small amout of repair work required, all the work is in the removal and reinstallation. So what is involved? Is this difficult?
Depends on your patience and skill with the hogring pliers. It's not that difficult to strip them and get them back on. I would think the stitching is more of a specialized skill.
If you decide to tackle this you're probably not going to be able to get the seat covers off without ripping the seams a bit more if they have shrunk (as most of our seats do) over time.
I would thoroughly treat the leather in an attempt soften it so that removal/replacement is easier.
If you decide to take it to the installer see if he'll knock half off the price if you bring the covers already removed from the seats for him to repair and reinstall.
Hey Man
If you can warm up the seats first they will come off much easier. Even a heat lamp in a large cardboard box helps. I also suggest your shop install a nylon binding tape over the repaired seam or it will tear again, Porsche should have done it originally. When you reinstall the covers, dust the foam plugs with talcum powder first and they will slide back on much easier. I think the key to getting them back on right is slipping your hand under the covers anywhere they look like they are wrinkled or cockeyed. Do it right before you hog ring them or they will always shift at the edge of the bolsters. Sometimes you can 'massage' the covers to re-shift the foam after they are installed.
Looks like a good repair!
So what's this about "wire rings" and "hog ring pliers". What wire rings are we talking about, and what do hog ring pliers look like? Be kind, I'm a city boy...
OK, assuming I can hog rings and hog ring pliers from an upholstery supply or wherever, what do these have to do with removing and reinstalling the seat covers?
Geaux Tigers!
I'm totally redoing a set of Sports Seats right now. Honestly, $200 sounds like a bargain to have the covers taken off, sewn and re-installed.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
+1 on applying leather conditioner. Buy a can of LEXOL leather conditioner. Rub it into the leather and let it soak in for a while and then wipe off excess. Let dry for 24 hours and apply another coat of conditioner and do the same as before. This should help prevent any more tears while removing the seat covers and make them supple once more.
Cheers,
Larry
Cheers,
Larry
I've got some leatherique products on the way, so I can give the covers a good conditioning before attempting removal. I'm wondering whether I should forget about it, if it's that much hassle -- which is why I was asking about the procedure in the first place.
Is there a write-up anywhere that anyone can point to?
Geaux Tigers!
courtesy of Rennbay
http://www.rennbay.com/944seatstutorial.html
You've got an advantage as your seat covers are already fitted to your seat over the car's age. The one's I'm working with are virgin leather and probably takes a little more patience to make it work.
