Feeler: Phenolic intake spacers
Old 06-25-2012, 07:13 PM
  #106
86 951 Driver
86 951 Driver's Avatar
Supposedly these make a big difference on the 3.5 V6. I don't know why but they see quite a bit of a gain. I saw it the other weekend at the dyno day I was at.
86 951 Driver is offline
Old 10-31-2013, 10:52 PM
  #107
eman930
eman930's Avatar
These still for sale?
eman930 is offline
Old 10-31-2013, 11:19 PM
  #108
V2Rocket
Rainman
V2Rocket's Avatar
Hi,
I am going to be doing some dyno time soon to log my before/after Rogue NA-tune as well as my supercharger, and could make time to do one with the spacer too...
Could finally bring this thread to a close.
V2Rocket is online now
Old 11-01-2013, 01:19 PM
  #109
Chris@Fabspeed
Former Vendor
Chris@Fabspeed's Avatar
I have a phenolic spacer kit right here, and a dynojet as well. I also have a Zeitronix ZT-2 so I can datalog air intake temp deltas.
I have a few spare N/A intake manifolds - I will drill & tap one of them to accept Zeitronix's air intake temp sensor and place this as close to the cylinder head flange as I can - this is where we will see the difference from a phenolic manifold spacer kit. I will do this to a spare manifold as it is not ideal to place a sensor right in the inlet runner, but, necessary for this test.
I will post the data logs as well as the dyno data. I hope to accomplish this in the next 2 weeks.
Chris@Fabspeed is offline
Old 11-01-2013, 02:16 PM
  #110
Van
Van's Avatar
If the results are measurable, I'll buy a set.
Van is offline
Old 11-01-2013, 03:31 PM
  #111
V2Rocket
Rainman
V2Rocket's Avatar
More scientific than I was intending, have at it.
Be interesting to compare how our cars react to the spacer, making this perhaps a more accurate test!
Old 11-01-2013, 08:49 PM
  #112
eman930
eman930's Avatar
Sweet! I'd grab a set, can't wait to see the results.... This would probably help more on a 951 then a 944 no?
eman930 is offline
Old 11-01-2013, 09:17 PM
  #113
Reimu
Reimu's Avatar
These are for heat mainly, right?
I'd imagine the turbo tucked up under the intake is heating it up more than being bolted to the head on a 951.
Reimu is offline
Old 11-02-2013, 01:38 AM
  #114
Gawernator
Gawernator's Avatar
Interested if good gains on a dyno
Gawernator is offline
Old 11-05-2013, 03:28 PM
  #115
locke
locke's Avatar
this came back from the dead. Right on though! I've been watching this with some detail and keep hoping for the best. I personally could see this working out well mostly with a retune. I don't think the O.E. D.M.E. would make sufficient use of the benefits. though I'm sure with rouge ant at the D.M.E. helm, I could be proven wrong. Sure, heat soak at the intake manifold is nearly a non issue at higher RPMS at high velocity, however. To keep intake runner temps down through stop and go traffic can only benefit the engine as a whole. Even if it doesn't immediately show benefit on a dyno, who's too say you can't compensate for the additional injector length with changing the injector firing timing, fuel pressure, pulse width, or change out for high impedence? (scary I know). play around with ignition as well. this may seem a bit overkill, but if you have the adjustiblilty, find out what kind of tune it would need and go with it. As we have seen from rouge ant, just changing out to a MAF (that he designed), a different tune, and advancing the O.E. camshaft can make a significant difference. I'm curious what the dyno would say about all this stuff with the addition of a webcams or J.M. camshaft. Myself, I'm not plagued with "oh, it's n/a" or "it's only 150hp?" It's already a Great car, though every bump in tech applied to it doesn't hurt!
locke is offline
Old 11-05-2013, 09:18 PM
  #116
ideola
Former Vendor
ideola's Avatar
ideola is offline
Old 11-06-2013, 03:56 AM
  #117
morghen
morghen's Avatar
Originally Posted by ideola
+1
morghen is offline
Old 11-06-2013, 11:20 AM
  #118
phlfly
phlfly's Avatar
well I buy as well if it can help gain ~ 5 hp or more. Do the dyno.
phlfly is offline
Old 12-31-2015, 01:59 PM
  #119
CO951
CO951's Avatar
Bump! I saw a mention of these phenolic spacers (http://philsautomotiveltd.com/wp/?page_id=2) in another recent thread. The concepts are sound and my manifold gets very hot at the track, but I was curious if there was any proof they are effective. Has anyone ever figured out if they are effective or not?
The best testing I could find was this http://www.autospeed.com/cms/article.html?&A=110474 that was done on a Mazda. Better than most but not as good as was discussed on here.
CO951 is offline
Old 12-31-2015, 03:21 PM
  #120
ideola
Former Vendor
ideola's Avatar
My popcorn has gone stale more than once waiting for people to post real data. The problem with all of the data I've seen in articles like the one you cited is that it measures the temp of the intake manifold material itself, and not the air within the manifold. I'm unconvinced these have any merit until someone posts real data showing reduced intake AIR temps.
ideola is offline
Quick Reply: Feeler: Phenolic intake spacers
