help! stripped hex's cant remove seat.
I removed my passenger seat without problem. My driver seat I have 2 hex bolts that are stripped. How do i get these out?? Can they be drilled out? I need your help desperately.
What do you mean by hex? Is that what we in uk would call an allen bolt ? If so try hammering in a slightly larger size torx bit as this will usually work.If not then tack weld on a nut and use that.
For real though ..... If you can get a drill on them, you CAN drill the heads off. Then hopefully vise grip the stud out...
The method I would begin with is using a hammer and punch. Use the punch on the side of the head. Try to hit them around in a circle to loosen them. (Hard to explain what I mean, ask if I need to try to explain again)
No, not Mosquito!
-Saw a slot in the head of the bolt and use a flat-head screwdriver.
-Vice grips
-Hammer and large flat-head screwdriver. Angle the driver on the head and pound the head in the counter-clockwise position. In other words: hammer it loose.
-Vice grips
this happened to me on my white car! Dremmel fits between the tracks nicely. First try to cut a slot for a screw driver, then hit the screwdriver with a hammer to seat it before trying to turn it.
It only took me about 15 mins and multiple curse-words! haha
realy not that bad with the dremel and cutoff wheel.
EDIT: Marquito beat me to the process. dremel makes the process faster, though!
If you resort to drilling, use a left-hand twist drill about 1/4" diameter. 9 times out of 10, after a few turns, the bit will bite into the screw and start twisting it out.
EZ-outs break off in the bolt as often as not.
These are the ways I would try in order of ease and sureness... Torx, if it dont work try Slotting the Head, if that dont work reverse drill with counter clockwise cutting drill bit...
