exhaust mid-section rattling
I was able to get the car on a drive-on lift today and had one of the shop guys operate the throttle while I looked under the car. It's been buzzing a lot and it seems to be coming from the cat. It is either buzzing against the heat shield or something in the cat itself is loose.
Does someone have a mid-section or test pipe FS or that I could borrow, or know where I would be able to get one? I'd really rather not have to do any welding. I'm thinking about unbolting the mid section and just trying to hollow out the cat. Because I'm an active duty military member living outside my state of residence, I don't have to get the car inspected, so I could just straight pipe it but I don't want it to be loud and smelly.
Ideas anyone?
Ideas anyone?
I wish test pipes weren't so expensive. I'll probably just gut it or buy another identical section from DC Auto and see if that piece rattles.
Other thing I'm trying to figure out is engine mounts...I bought "OEM" I think either Meyle or Mahle engine mounts awhile ago for about $75 apiece but they are totally collapse and the engine shakes as bad as ever. Do I go $400 for a pair of Porsche mounts or about $300 for lindsey or pelican parts aftermarket mounts? They now offer ones with dampers instead of just solid mounts but I haven't heard of anyone using them.
Guys, part number 24 is an old piece of emissions testing gear that no longer serves an purpose. Most of yours were removed or rusted off.
Colin, you think it would be a pain to ship? There's something to be said for bolting in. Let me investigate more and get back to you.
It sounds fine at idle, but it buzzes at 3k rpms and about 5k rpms. Worse when under load. When you're actually driving it sounds like a ricer fart can when you shift.
