now what did i break???? suspension issue. PICS ADDED
I would probably remove that shock and see how it feels by hand. If it went dead, you'll know.
Other than that I would check all the rear suspension bolts for proper torque and give it a thorough looking over.
1 Post
ill check tomorrow for a bad shock. if its dead will i just be able to compress it with my hands?
also tonight i think i heard some tire rub coming from that corner (not normal). i will also check for that tomorrow.
the shock does not determine your ride height. u could remove the shock altogether and it should be at the same ride height.
jack up the car and put it on jackstands. take off the wheel. undo the sway bar endlink. grab a hold of the suspension and move it around. something should be plainly obviously very loose....i would imagine.
1 Post
do it at the endlink. i'm trying to basically unload the suspension in all directions so you can jiggle it around and see what's loose. even if u undo both droplinks, the other side of the sway bar will still hold the pass side in place.
1 Post
arent the endlink and droplink the same thing? small dumbell looking things. does it matter which end i unbolt (end attatched to the sway, or end attatched to the spring plate(?))
yea same thing. undo whichever is easier. the sway bar side is prob easier than the spring plate side.
A normal shock doesn't affect ride height. Mine thought was that it failed and is now binding the suspension. Compressing it by hand should tell if it's ok. If you don't know what to feel for, you can remove the other one and compare.
1 Post
lol, he is a hefty guy, but no.
i will be the first to say i dont know much about working on vehicles, but im not that dumb. besides, flat tire would not decrease the space between the wheel well and the top of the tire.
binding is what i meant by something getting stuck, and this was my first guess, but what would cause that to happen?
If that's the case then I'd go back to my eccentric bolt theory -- at least as something easy to rule out.
