Oil Pressure is going nuts!! Help!
Last week I was seeing normal pressure (4.5 BAR) at cruse speed. 5 BAR @ start up and ~2.5 at idle. Then my oil pressure started dropping to ~3 BAR at cruse. It's still good @ 5 BAR on cold start up and idle is fine too. The REALLY strange thing is, the pressure drops when I push on the accell. at speed. I don't understand. Could it be the pressure sensor? Do I have a leak? There is no coolant in the oil of oil in the coolant. What is going on?
Senders arent very expensive, get a new one. I have the same problem as you, but One day it just pegged whenever I turned the car on. I knew it was the sender because the it would read 5 + BAR when the engine was off but key in second position. It is a pretty simple fix.
Christian
Christian
Sorry, I ment that I HAD the same problem. Now that I have the new sender all is well.
Christian
BTW, just wait till you plan on changing the oil anyway, no sense it doing it twice in the specified period.
Christian
The wires for the oil pressure sender run near the exhaust manifold and over time melt and rip and get covered in oil, they are usually culprits of jumpy needles as they can cause intermittent contact.
Christian
Christian
Yeah my needle pegs 5+ as soon as I turn the key. I have a new sender sitting here waiting to go in next weekend when I do the oil cooler seals along with everything else.
This sender is the same for the following:
924S 1986-1988
928 1978-1988
944 1983-1990
944S
944 S2
944 Turbo
911 C2 thru 1994
911 C4 thru 1994
911 Turbo 1991-1994
968 All
911 Carrera 1995-1998
911 C4 1995-1998
911 Turbo 1995-1998
924S 1986-1988
928 1978-1988
944 1983-1990
944S
944 S2
944 Turbo
911 C2 thru 1994
911 C4 thru 1994
911 Turbo 1991-1994
968 All
911 C4 1995-1998
911 Turbo 1995-1998
