Colorado GTG?
#137
Small Business Partner
#138
I have a Guru MAF chip programmed for stock injectors I bought a few years ago but never used myself. I was mainly interested in the software on it, long story. Anyway it's possible it might run OK with your MAF and stock injectors. You can use an elbow in place of the recirculating valve to prevent incidental boost. A Vitesse chip for stock injectors might be better.
#139
I would not use a chip programmed for one MAF with a different MAF - they could have vastly different calibrations (transfer functions), causing incorrect fueling and timing... Not a good recipe.
The elbow in-place of the DV is a good idea
#140
Hmmm, I wonder if Vitesse can burn another image on my chip for the MAF and stock chips basically for smog purposes.
Won't the car still make boost with the elbow in place of the bypass valve?
#141
Any of you Colorado guys have 1 good lifter for a 944?
We did s track day at HPR yesterday and Kyle lost 2 lifters on the same cyl. I have 1 for him. We just need another today to get his car up and running for the PBC drive tomorrow.
You can call or text me. 303 359 7469
