No low end power
09-28-2009, 10:17 AM
Got Nothin'Rennlist Member
No low end power
Just finished belts and waterpump. Car ran great for a while.
Had to replace the cap and rotor, due a bolt backing out, and destroying the rotor. Put it all back together, now I have no low end power. Accelerating from a light, the car cannot get out of it's own way. Gets a bit better as the car warms up, but the low end just isn't there.
09-28-2009, 10:22 AM
Cam timing or firing order out of whack?
09-28-2009, 10:24 AM
Firing order is good.
Will check the timing, but it was spot on, before I replaced the cap/rotor. (after the water pump and belts).
09-28-2009, 10:32 AM
Does it sound like it's running rough?
If the timing is right, then I'd look at something blocking the intake tract.
09-28-2009, 10:35 AM
It sounds good. Will look at the intake.
09-28-2009, 02:34 PM
Resistance is FutileLifetime Rennlist Member
Quote:
Originally Posted by
PeteL
You love to pull plugs... check there first.
09-29-2009, 02:05 PM
I will. It is running a bit better. Drove it to work yesterday and today.
It just has problems first thing in the morning, but who doesn't?
09-29-2009, 02:14 PM
RainmanRennlist Member
09-29-2009, 02:24 PM
I assume original. I have had the car for 12 years.
09-29-2009, 02:49 PM
Now that is interesting...
09-29-2009, 03:50 PM
my car felt sluggish when cold before and when i needed to smog it failed, replaced the cat and it picked up and also passed smog
09-29-2009, 04:43 PM
09-29-2009, 05:06 PM
Sounds like a vacuum leak to me.
Check around for any disconnected or cracked vacuum lines, loose hose clamps on the intake boot, etc.
09-30-2009, 09:26 AM
Kinda where i am leaning.
