Urgent help needed...I have my injectors out and the kit is different!
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
I bought the fuel injector kits from Pragon and they have the same O rings and yellow 'hat' as what was on my injectors, But the support ring is much thicker, grey instead of orange and a bit larger ID.
Which do I use, If I use the one supplied, this will push the Hat out further.
Also, when replacing the hat. Do I just push it on till it snaps in the groove, or all the way till its flush with the O rinG.
Thanks, I'm waiting till I find out what to do.
I just called Paragon, they have not had the question come up before...So do I use the new washers which would move the 'hat' further out and change the spray patern, or use the factory washers?
Set to Full-Auto
When I did mine I bought the kits from my local friendly NAPA (at the time I was unaware of Paragon) and they fit just fine for a price of $3.00 each.
I think I must be a fool...I believe the grey washer is used with the extra o ring for the pressure regulator. I need to reuse the old washer.
Oh, Well
Oh, Well
This question HAS come up before --and with paragon. When I replaced my head gasket 2 years ago I couldn't figure out why the injectors didn't fit right. The grey things(washers--whatever) were too big. After 4 or 5 phone calls no one had an answer and they even ordered a new set from another supplier and STILL couldn't figure out what the deal was. I ended up sanding the washers thinner and putting them in. I still have an idle problem to this date but have no time to chase it down.
Lifetime Member
Lifetime Member
This question has been asked (and answered) many times. The standard "factory" kit has too many o-rings, the wrong washer and no filters! Markus Blaszak sells his own kits for around $7 that has all the right parts: 2 washers, one hat, and one filter. You must re-use the washers, but they are not a wear part anyway. So what filter am I talking about? If you turn a sheet metal screw into the top hole of the injector and pull, you will extract a fine mesh screen filter in each injector. Once you see one, you'll never want to reseal an injector without a new filter again!
<a href="http://www.blaszakprecision.com/" target="_blank">http://www.blaszakprecision.com/</a>
