As title states, these will only work on early 944s and the 2.0 924. Apparently they would hit the dash on a later car. These are in good shape and are an easy swap. According to an older thread I came across the conversion saves around 10 lbs and no more switch problems!
These are a direct swap into early doors but you will need to make a hole in your door card for the crank to go through.
