EMERGENCY! Need a Transaxle ASAP!
Old 09-06-2009, 03:14 AM
badcoupe
badcoupe's Avatar
I have a 57k mile 86 turbo one, non lsd with cooler
Old 09-06-2009, 10:35 AM
Van
Van's Avatar
If Mike051 doensn't have anything for you, I have a standard NA box that I'd part with for $500. Good shape, no problems. I'm about 1.5 hours from the NJ-NY boarder - and around all weekend.
Old 09-06-2009, 10:57 AM
knfeparty
knfeparty's Avatar
lol sorry just offering what I had....it IS equipped as what you wanted after all. I just want it back eventually ha ha.
Old 09-06-2009, 11:07 AM
msailer
msailer's Avatar
I have a good transaxle out of '85/2. I would like $600 for it.
I'm about 3 hours from you. If we can meet half way on I80, I can get it to you fast.
Old 09-06-2009, 01:29 PM
thewerxracing
thewerxracing's Avatar
Thank you so much for the super-quick replies; it's great to know people like you guys exist to help a stranger get problems sorted. However, the team has concluded that we're not taking the 944 to the vintage this weekend. Work prevents me from installing the rear end anytime before thursday, and thursday is the start of practice for the weekend.
So, I'll still be in need of a new transmission, but now I have the time to get EXACTLY what I want.
-Short 5th
-L.S.D.
-Maybe a Trans cooler ( I didn't even think of that...tell me more.)
So, I'll be shopping around and starting this ****ty process.
Good news is I'll be driving Dad's Vette.
Thanks again guys..
Old 09-06-2009, 02:12 PM
V2Rocket
Rainman
V2Rocket's Avatar
a turbo trans has a short 5th...problem is everything else is tall lol
trans cooler only came optional on turbo trans, i imagine it would be doable on an NA unit but not really necessary and youd need to figure out a pump mechanism.
if i had the time id take the 5th from my NA box put it in my turbo box and put the turbo 5th in the na box and sell it to you lol
Old 09-07-2009, 01:53 PM
thewerxracing
Okay. I just picked up a S box with a short 5 and LSD with 0 miles on it. It was freshly rebuilt. The only problem is now I need to know what to put in it. How many quarts of what kind of gear oil and should I be using LSD additive now?
Old 09-07-2009, 02:03 PM
thewerxracing
Also when installing a short throw shifter, does that replace the shift linkage on the top of the transmission? Because as it turns out, the shift rod that goes out to the car and the shift linkage on top of the transmission sort of fused themselves together...they had to be cut and the shift bar had to be re-drilled. Now I hope that the short throw replaces the rod on top of the transmission.
Old 09-07-2009, 02:58 PM
V2Rocket
Rainman
V2Rocket's Avatar
that must be such a nice feeling box lol
whered you find it and how much?
i use lucas heavy duty gear oil, something like 80w140 lol. works nicely. used the same stuff on my truck when the LSD on that started to chatter a bit, fixed it right up
Old 09-07-2009, 03:02 PM
thewerxracing
I got it from 944 ecology for two grand. Thanks!
Old 09-07-2009, 10:05 PM
hardtail15
hardtail15's Avatar
sent you a PM
Old 09-07-2009, 10:30 PM
V2Rocket
Rainman
V2Rocket's Avatar
pricey but seeing as it has 0 miles and LSD imo worth it
Old 09-07-2009, 11:12 PM
Van
Van's Avatar
George is good people. It should serve you well.
I use Mobil 1 Delvac. You fill it up till it starts to run out of the fill hole... Just under 2 quarts, I believe.
Old 09-08-2009, 12:26 AM
Tom M'Guinn
Tom M'Guinn's Avatar
For reference, Vertex in FLA sells rebuilds.
http://www.vertexauto.com/ShowItem/4...5%20Speed.aspx
Old 09-08-2009, 02:01 AM
Yummybud924
Yummybud924's Avatar
what exactly causes the ring and pinion to blow up like that? Is it hard take offs? doing burnouts?
the 944 doesn't have much power with 140-150 hps and 130-140 tq why would the transmission blow up like that?
Quick Reply: EMERGENCY! Need a Transaxle ASAP!
