Has anyone filled the panel seams in the back?
Like Cole said if you get rear ended it will not be a simple unbolt and replace the dented part if needed.
I actually think about taking a rotozip and putting the seam line back on the car. Then I would have to repaint the area, but if anything was to happen to the back of the car and I needed a repaint in that area I will do it for sure.
I filled in my rear body seams. That's a welded seam, so if you have flex there.....well, you have other problems, ya know ! I also filled in my front and rear fiberglass bumpers, as well as filled in front and rear side lights. It needs paint, but I like the smooth look. Contemplating removing the door handle and filling in as well. Would do remote power locks, but also leave a hidden cable operated latch release fro one of the doors in case of battery failure or power lock problem. Must just be me, but I like the smooth body look. Ya, ya, I know you can't remove/replace body parts separately, but hey that's my burden to bear.
