FS: 944 951 Koni Shocks/Struts and Sway Bar
Koni yellow adjustable rear shocks with ~28K on them. Same as on the M030 951s. - $120 plus shipping
18mm rear sway bar. Same as on the M030 951s. -$50 plus shipping.
Koni yellow adjustable front struts from an '86 951 with M474 sport suspension. Passenger side leaked some fluid. They come with 3 dot springs and upper strut mounts. - $60 plus shipping SOLD
Pics and more description in the members classifieds section:
https://rennlist.com/forums/for-sale...-sway-bar.html
I bought the 19mm adjustable before measuring the one on my car. Only after intalling the 19mm and not noticing a difference in performance did I measure the original bar and find it to be 18mm. Since it was already installed, I just left the 19mm there and decided to sell the 18mm.
The 30mm sway bar was originally paired with the 19mm adjustable rear sway, which at it's softest or maybe even the middle setting would be equal to the 18mm. It all depends on how stiff you want it.
sounds reasonable, i cant imagine 1mm does a lot (unless its different steel) i would also be pairing it with the kla adjustable drop links (my car came with the sway bar missing) so theoretically, this could be "almost" the same as the 968 unit, correct?
