I need 944 automatic tranny flex disc
Old 07-30-2009, 01:32 PM
JayRogers
JayRogers's Avatar
Default I need 944 automatic tranny flex disc
Does anyone have a random Auto Flex Disc kicking around they don't need? I just pulled my engine out and low and behold that lovely little disc crumbled before watery eyes!
Anyone know where I can get one cheap? I don't have 1200 bucks to drop on a new one.
Old 07-30-2009, 01:46 PM
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
EBay?
http://cgi.ebay.com/ebaymotors/Porsc...81710005r33367
This is a tough decision for the amount of work required.
Vertex new is $1029
GL
John_AZ
Old 07-30-2009, 02:34 PM
mehall
mehall's Avatar
There's a New-in-Box FS in the classifieds of Panoram magazine. He's asking only $600. If you don't have a copy, I'll dig out the info this evening.
Mark
Old 07-30-2009, 03:02 PM
Calmchaos
Calmchaos's Avatar
I have a used one, I'll take some pictures of it in a second. It always worked well. Don't need it anymore cuz I converted to manual transmission.
I also have a good shifter cable for an automatic if you want to replace that while you're in there.
EDIT: Pictures...
Let me know what you think. If you want it, I won't ask much for it. I'm posting the pictures instead of PM, because I don't know what kind of shape this is for a flex plate. I don't know how long it will last.
Old 07-30-2009, 11:47 PM
JayRogers
JayRogers's Avatar
Calmchaos, thanks for the pics. It looks a little rough. But if you pull or push on it does it look like it's going to fall apart?
Do they make an aftermarket plate? Does anyone know what's it's actually made of? is it just rubber? What's it main function. I know it's the contact point between the engine and the drive shaft. Does it need to be rubber? Can I make one out of a composite?
Man I hate cars!
Thanks all. (Found the one on ebay, I put a bid just to see if I'd get it. If it sucks I'll compare it to yours calmchaos and if yours is better we'll talk business.)
Old 07-31-2009, 09:16 AM
marky522
marky522's Avatar
I have hard some people just use a clutch, but you would need to get some other parts.
Mark
Old 07-31-2009, 05:50 PM
JayRogers
JayRogers's Avatar
Mark, What other parts would I need? I have an entire clutch assembly. Would I use the manual flywheel and clutch disc?
Old 07-31-2009, 06:32 PM
WizPorsche944
WizPorsche944's Avatar
It would be better to just convert it to stick.
Old 07-31-2009, 09:21 PM
marky522
marky522's Avatar
You would have to search on here, I think it was legoland that did it.
Mark
Man I hate cars!
Old 07-31-2009, 09:45 PM
rattlesnakeracing
rattlesnakeracing's Avatar
Post Auto Transmission Damper
The basic reasoning is that you are taking out what some call an automatic clutch (damper & flywheel) and in that same space putting in a manual transmission's flywheel, pressure plate, clutch disc, and starter ring. Essentially replacing rubber with metal. Sending you a PM.
Quick Reply: I need 944 automatic tranny flex disc
