944 Vibration Question
When my 87 944 is at idle I have a very bad shudder/vibration. When I give it gas and the rpms go to around 1100 the car is as smooth as silk. I have only had the car a few weeks so I don't know much of the history about it. My first take is that possibly the balance shafts are slightly out of adjustment. But I also notice that the idle RPM's fluctuate between approximately 800 to 900 rpm (constantly when at idle) This could possibly be a bad Idle Stabilizer. What do you think?
I picked up an 86 944 and have the exact same problem.
I've done the following with NO improvement:
Engine Mounts - changed with aftermarket units
Plugs/Wires/Cap/Rotor - all changed / new Bosch
Air Filter - Mahle factory filter
Alternator/a/c belt - replaced
Balance shaft belt - alignment checked and retensioned
Timing belt - checked OK
DME temp sensor - replaced
Throttle body - cleaned out
WTF?? My 88' turbo S ran like a turbine. I'm not sure what's going on here......
prob two seperate issues
idle fluctuate = either idle stabilizer or there's a vacuum leak.
shaking = BS out of time, motor mounts, ....other possibilities.
i thought idle was supposed to be around 800 or so..
