another shaking thread
Old 07-16-2009, 01:55 PM
Eastep
Eastep's Avatar
Default another shaking thread
so yeah... when traveling at a spirited rate and I need the slow to a stop steadily, the steering wheel shakes like a *****. any thoughts on the problem? bad lines?
Old 07-16-2009, 01:58 PM
JohnKoaWood
JohnKoaWood's Avatar
Brake rotors heating up... I would suggest changing them, goto vented, or even gas slotted.... I chose cross drilled and have absolutely no issues with rotors warping even when "slowing at a steady rate from a spirited rate of travel.."
Old 07-16-2009, 02:02 PM
Eastep
Eastep's Avatar
are there any factory vented/drilled rotors that'll work, that i should be on the look-out for in the wrecking yard?
Old 07-16-2009, 02:09 PM
V2Rocket
Rainman
V2Rocket's Avatar
regular zimmerman rotors should be fine...crossdrilling under hard use can lead to cracked rotors
Old 07-16-2009, 02:10 PM
JohnKoaWood
The ones I put on my 951...
http://www.944online.com/cgi-bin/ASI...akesystem-9442
make sure you get the ones for the right year...
http://www.lindseyracing.com/LR/Part...RAKEROTOR.html
http://www.paragon-products.com/pors...iscs_s/256.htm
http://www.pelicanparts.com/catalog/...pg4.htm#item17
pick your poison, or price point, or desired kit, or whatever you want to go with...
I have heard bad things about the cross drilled rotors breaking on the track due to heat, but have had no issues on the street.. if I had to do it over I would probably use the same kit again... the pads definately make for solid brake feel, and the fluid is top notch... just make sure you get the right year...
Also make sure to check your wheel bearings... make sure they are packed with fresh grease, and installed correctly...
Old 07-16-2009, 04:56 PM
supes6
supes6's Avatar
Cementite buildup on the rotors... usually happens after you brake really hard and then sit at a light with the brakes clamped. An imprint of the brake pad on the rotor is the telltale sign. It creates a hot spot on the rotor which will cause the vibration.
Old 07-16-2009, 05:10 PM
Eastep
Eastep's Avatar
no nothing like that, its braking at speeds abouve 60 that this occurs, never in town or at lower speeds. I think the entire underside of the car needs a going through. the car doesnt feel very sure footed at speed or in the corners. the car is "wallowy" and soft feeling. Im gonna replace the lines,bushings,steering rack with manual & tie rods, add a rear sway bar, and uprate the pad material/brand. Also I have some super blue racing fluid Im gonna use instead of stock DOT3
Old 07-16-2009, 06:04 PM
V2Rocket
Rainman
V2Rocket's Avatar
how old are the shocks
Old 07-16-2009, 06:42 PM
Eastep
Eastep's Avatar
idk, ive only owned the car for like 2 months. they could be OE for all i know. they feel a lil softter then when i first bought the car so... Anyone have any comments on KYB's for our cars? I have front coilover (yet to be installed) that i wanna use
Old 07-16-2009, 08:04 PM
Swagger93
Swagger93's Avatar
Dude your front rotors are smoked. They're helping to further mushify your suspension, too.
Old 07-16-2009, 08:22 PM
supes6
supes6's Avatar
nothing like what? you said there was vibration through the steering wheel when you brake and I gave you the most likely cause. yes, the vibration usually is most noticable at highway speeds. your whole suspension could be shot as well, but if you want to solve this problem then you need to look at the rotors. new pads and brake fluid won't fix anything.
another possibility is that your rear brakes are not working properly, putting more stress on the fronts and making them overheat... which leads to the cementite problem and the vibration.
Old 07-16-2009, 10:15 PM
V2Rocket
Rainman
V2Rocket's Avatar
karl who is that angel in your avatar
Old 07-16-2009, 11:06 PM
Eastep
Eastep's Avatar
i was saying thats its not a matter of buildup on the rotors. The rears apear to be fine. It almost feels as if something is loose in the suspension/braking system up front. I know the bushings are probably not helping matters. I never said new pads or fluid would fix it. I said i was going to change the fluid and pads to higher quality stuff while im at it. The fact that i have a manualized PS rack probably adds to the vibration. its more in the pedal then the wheel.... well 50/50
Old 07-17-2009, 05:23 PM
supes6
supes6's Avatar
zuzana z... I think that was about the tamest pic I could find of her!
Old 07-17-2009, 05:38 PM
JohnKoaWood
OMG..
Quick Reply: another shaking thread
