Parts fs-garage clean + MORE STUFF!
as usual i have too much stuff blocking up precious space on my shelves. This stuff needs to leave.
Everything OBO
-new DS early offset a-arm- rebuilt never installed w/ 968 castor block-$65SOLD
-used early offset rear turbo trailing arms-same as n/a-w/ bearings and hubs-$30SOLD
-H4 headlights w/ bulbs work great, good shape- $50SOLD
-convertible quarter panel caps- ds has one small chip in the very end-$55
-burgundy center console w/ ash tray and shifter surround-$45
-burgundy headliner/sunvisor panel w/ light- $15SOLD
-guards red sunroof w/ black headliner-good shape - $25
-Yokohama ES100 205-55-16 tire- 80% tread or better-one tire-$25
-porsche crest valve stem caps- won them at the fest- dont need them $10SOLD
-set of TurboS or s4 mintex brake pads- $30SOLD
-cricket belt tension tool- bought and rarely used-$10
-SPEEDLINE factory center caps x2 - about 2" diameter- $40
-set of six turbo stickers for center caps- bought and not used about 2" diameter-$5SOLD
-turbo motor mount/turbo mount w/ AOS hose- $30 each
also have many other parts just too much to list, n/a intakes, dash trim, old coolant tanks, bellhousings, n/a header, engine mount brakets, n/a cat converter, heat shields, 924S ps fender, front and rear bumpers, wrecked euro front bumper, broken AIR splitter(needs serious repair but have most broken parts)SOLD, 968 lower rear leather black seat, burgundy ps door panel, windows, hatches, etc etc...
added 7/11 -
-J-pipe, coupler and k$n filter- i'll throw in the Autothority MAF since im not sure it works - $100SOLD
-Stock J-boot for turbo and AFM unit- $40
-K26/6 - dirty but boosts fine w/ coolant pipe -$40SOLD
-n/a early block w/ VERY little scuffage on the cylinders-has been steam cleaned and sitting in my garage. NOT PERFECT but ive seen much worse in nice running cars w/ good compression. $35 pick up only.
added 7/11 -
I am going through a HOT start issue and would like to take the ignition coil, cap and rotor and wires if they are not old/ many miles. How many miles are on those things, did you install them, condition? Also, have a pic of the crest? Mine is terribly beat (chips, very dull, missing/ chiped off red and black paint.
Thought you said to many other things too list. Really only need the Ignition coil, thats the top priority for me. If you dont have it, its fine.
i have some extra coils from running cars availble. $10+ship.
not sure what the Ecodes are - pretty sure these are DOT but i can check- just stock bulbs in these lights.
seal is still on the sunroof. Im going to pull it out and inspect it alittle better.
Lights say H4 then E4 on them- not sure if that is E code but ....
I need the plastic pieces from the rear of the sunroof, and I could use the interior panel, so if you haven't sold it, I'll give you 35 for it! (plus shipping, either for the whole thing or just those parts)
"new DS early offset a-arm- rebuilt never installed w/ 968 castor block-$65"
i only have one control arm- drivers side- early offset as i stated.
RedRose-you need the inserts on the rear of the sunroof- i should have those- i have a cover as well but its brown/burgundy-i think its brown hard to tell.
Lights are gone.
I also have some stuff im pulling from my LeMons entry that i wont be using
-good sunroof deflector with GOOD arms!!! $30
-new rear hatch shocks-like brand new-$30
more to come...
Lights are gone.
more to come...
