Q: re installing stainless brake lines.
The new lines all have female ends. The OEM lines I'm taking off have male ends (eg thread into the caliper). What gives? Does the male end come off the OEM brake lline?
M030 is all female, all others are male female if I remember correctly... The ones I got from Ians' are male/female and installed no problem...
http://www.944online.com/cgi-bin/ASI...ystem-944turbo
option for screws into caliper, or attaches to hard line... you got the wrong type...
Are you talking about the difference between the receptical on the strut or the sensor itself... My sensors (long since removed) were only really 1 wire, in a loop, break the loop, caution comes on... cut 1 inch from the plug, solder together, heat shrink.. no more sensors... the receptical on the strut also houses the conections for ABS sensors...
I can confirm this to be true on 87 951 as well as my 88 N/A... wiring is there, but no ABS sensors, brain, control pistons, lines..etc...
