WTB- Valve cover for a 2.7L engine!
05-10-2009, 12:24 PM
i need a valve cover from a 2.7 aftermarket or original
05-10-2009, 12:40 PM
05-10-2009, 12:46 PM
05-10-2009, 12:52 PM
Not SpecialRennlist Member
There were only 2.5 L 16-valve (S) and 3 L 16-valve (S2).
2.7 was the one-year 2.5 8-valve, I believe.
05-10-2009, 12:53 PM
Hey ManRennlist Member
05-10-2009, 01:01 PM
83-88 -2.5L 8v
87-? -2.5L 16v
89 -2.7L 8v
89-? -3.0L 16v
05-10-2009, 01:48 PM
RainmanRennlist Member
i wonder what the result would be of a 16-valve 2.7 engine, like an S2 head on the 89 block.
totally not worth it lol but out of curiosity
05-10-2009, 02:30 PM
2.7L camtower is the same as a 2.5L. There is no such thing as a 2.7L valve cover let alone an aftermarket one. Why are you replacing it?
05-10-2009, 02:57 PM
i have a head.... with twin cams...... off a 944 of some kind. whatever it is. i need the cam cover for it.
the 16 valve one.
05-10-2009, 03:50 PM
any way to measure a bore on it? like is there any gasket residue? or if you have a 2.5L 8v head laying around you can compare the two and if they have the same water/oil passages it is off an S, if they are different it is an S2
05-10-2009, 07:29 PM
ok... Liston it has 16 valves and twin cams. how many diffrent heads did they make.
05-10-2009, 07:44 PM
05-10-2009, 09:20 PM
05-10-2009, 09:33 PM
05-10-2009, 10:14 PM
Quote:
Originally Posted by
VOoDOoGTX
They made 2.5 8v NA heads, 2.5 8v turbo heads, 2.5 16v NA heads, 2.7 8v NA heads, and 3.0 16v NA heads.
