Motronic experts, stock timing?
Rainman
ill be pulling timing as far as the FQS lets me (2.77*) and richening the mixture all the way (+6%) for safety's sake, along with the A/W IC and meth injection. will my EGTs be too high with about 10psi boost?
1 Post
Everything you could possibly want to know about tuning and engine management: http://www.megamanual.com/index.html
Rainman
36# turbo injectors and meth nozzles im looking at are between 3-5 GPH at 150psi, which id activate at like 6PSI to give good headroom for the meth but also to save the stuff while just cruising.
would it make any sense to mount nozzles in series? is there a possibility of a dual-evaporation effect or does the first time take out most of the heat?
Small Business Partner
