Slave cylinder problem
I just replaced the slave cylinder on a 1986 951, bled the system and the clutch pedal is off the floor (fully up position). I can't push the clutch pedal down however. A quick check under the car at the inspection hole reveals that the release lever socket (the socket that the slave cylinder pushes against) is wedged against the bellhousing.
I can take a screwdriver and lever it back in place. However when I push the clutch , the clutch pedal drops to to the floor, springs back up and the pedal is locked in the up position.
My questions is if there is supposed to be a spring that returns the release lever back into the non extended position? I am really lost here, spent most of the day yesterday bleeding and messing around with this, I am out of ideas. I hope its something simple.
So to summarize, the clutch pedal is up, system is bled. Clutch pedal cannot be physcially pushed down as the release lever is at the extended position with the pedal up. Hope this is clear, and thanks for any advice rendered.
-Kelly
-Kelly
Hi, does the pedal snap down by itself when you push on it? If so, I suspect there is still air in the system. How did you bleed the clutch? Did you use a pressure bleeder, or did you use the traditional pedal pumping method?
If you have a pressure bleeder, bleed the system again. Bleed it first in with the pedal in the down position, opening and closing the bleed nipple on the slave cylinder, and progressively pull the pedal upwards repeating this operation. This will get the air out of the system. Ideally, you would finalize the bleeding process with someone pushing down a bit on the pedal while you open the bleed nipple one more time to get the last possible bubbles out, but you'll need a helper for this. HTH
P.S. Have you also checked your firewall for cracking? I just discovered I have this problem after difficulty bleeding the clutch hydraulics.
I used a pressure bleeder. The clutch pedal in the up position physically cannot be pushed down. When I check under the car the release arm is pushed up against the bell housing, this can be seen via the inspection hole. I already went through 1 litre of brake fluid via the pressure bleeder. The fire wall looks fine, no cracks.
The thing that puzzles me is the pedal being "locked" in the up position. Is it locked locked, or just very difficult to push in???
I took the slave cylinder out, the release lever does return to the non-extended position, it seems that the force of the slave cylinder rod exceeds the pressure of the return spring. I did not take anything in the bellhousing apart. I hade the clutch pedal drop to the floor and limped it back into the garage. I will try and bleed the slave cylinder outside of the housing.
The pedal is locked, as in can't physically push down with my feet. The ball end of the release lever is extended to the bellhousing with the pedal up.
less than 2000 miles ago, the clutch is pretty much brand new. I do not drive the car much. Was going to get the car smogged. There likely is no way to get to the required parts unless you remove the torque tube and do a whole clutch job right?
What was replaced in the clutch job? Did you include throwout bearing and clutch fork needle bearings? These parts can create problems, although I'm not sure it's your issue. My clutch fork was shot and replaced with a new unit back when I had mine done.
Could it be that the adjustment on the clutch pedal is extended to the maximum it can go. I don't know if I'm epxlaining this correctly but have you played with the adjustements of the pedal?
Have not played with the adjustment of the pedal, if the slave cylinder goes bad (clutch pedal to the floor), would it move the pedal out of adjustment causing this condition?
I just looked under the car again. The release lever does not return back to the non-extended position. Does anybody know how the release lever should return back to the non-extended position? I know that I likely will have to remove the bellhousing, but is there anything else that may cause the lever not to return back?
Wax On, Wax Off
the tension from the pressure plate (it's a giant flippin spring) should be more than enough to return the clutch release fork to it's normal position. somethings broke. sounds like a dead fork? Just happened to me, and a couple others I know.
Could be, but why is the clutch pedal "locked"? The clutch fork needle bearings have moved to #1 on my list of suspects - especially if we find out that they were not replaced during the clutch job. Mine were trashed at 106K miles.
